Go to Post "Don't worry, it's just a prototype." - Newo95 [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 13-01-2014, 21:04
jlian's Avatar
jlian jlian is offline
AKA: John Lian
FRC #4955 (LA Tech)
Rookie Year: 2014
jlian is an unknown quantity at this point
Easiest/most economical way to build a pickup roller
We were thinking about using a hex shaft with wheels. However, we're not too sure what the best way is to secure the wheels on the shaft (hex shaft collars + hex hubs seem a bit too involved/expensive)
I was looking at Team O-RYAN's Ri3D video and the wheels seem to be secured without much setup.
We are a rookie team so we don't have a lot of resources.. Nor do we have scrap material from previous years. Anything we want to build we would have to order.
Is there an easy way to build this pickup?
Unread 13-01-2014, 21:19
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Easiest/most economical way to build a pickup roller
They built their intake using very basic parts. To build an intake like theirs, I would pickup some aluminum square tubing from a local hardware store, shaft (preferably hex shaft from VEX), shaft collars, wheels that fit the shaft, bearings that fit the shaft, sprockets, chain, and a geared motor.
You can PROBABLY do without bearings
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 13-01-2014, 21:21
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Hex shaft collars are a great way to go! What wheels are you using? Some wheels come with a hex built in, if not, a hex VersaHub from VEXpro would be a great fit!
Unread 13-01-2014, 21:36
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Check out Banebot wheels. They are cheap and made to take hex shafts. or AM star tube.
http://www.andymark.com/product-p/am...m?1=1&CartID=0
http://banebots.com/c/WHB-WM-HS4
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 13-01-2014, 21:44
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
It's called a Churro Tube by the way
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 13-01-2014, 22:26
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Hex shaft, a couple of hex bearings, two Banebots wheels, and some PVC to use as spacers to hold the wheels in place--it'll last you all season and is about as cheap as a mechanism gets!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 13-01-2014, 22:34
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Still pretty cheap to get hex shaft collar clamps from Vex too!!
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 13-01-2014, 23:35
jlian's Avatar
AKA: John Lian
FRC #4955 (LA Tech)
Rookie Year: 2014
So I should get
- Aluminum tubing from local aluminum shop (http://www.alustock.ca/Square-Tube-SC-1x0.125-AMR1465)
- AndyMark or VexPro hex shaft (http://www.andymark.com/product-p/am-2291.htm?CartID=1)
- 2 BaneBots Wheel, 2-7/8" x 0.8", 1/2" Hex Mount (http://banebots.com/pc/WHB-HS4-298/T80P-295BA-HS4)
- 2 BaneBots Wheel, 3-7/8" x 0.8", 1/2" Hex Mount (http://banebots.com/pc/WHB-HS4-398/T80P-395BA-HS4)
- 10 (?) Clamping Shaft Collar - 1/2" Hex ID (http://www.vexrobotics.com/shaft-collars.html)
We have some geared motors (http://www.andymark.com/product-p/am-0915.htm) coming as a part of FIRSTChoice. What should we do in terms of sprockets: 25 series (http://www.andymark.com/product-p/am-2182.htm) + (http://www.andymark.com/product-p/am-0749.htm)?
Putting the shaft through the aluminum tubing - how is this done? Is there enough space for hex bearings?
Unread 13-01-2014, 23:44
androb4's Avatar
AKA: Andrew A.
So I should get
I would get the shaft and wheels from VEX just to minimize the vendors for convenience.
Unread 13-01-2014, 23:47
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
Well he might be using the BaneBots voucher
But yes, get the hex shaft from Vex..(cheaper)
Unread 14-01-2014, 00:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I'm a bit concerned about bending a 1/2" 7075 hex shaft over a 26" span. We've done it before. So, I'm considering using a 3/4" hex shaft. Am I out of my mind here?
Also, I'd like to build a pickup very similar to Ri3D 1.0, but I noticed, that robot didn't have bumpers. That's why it works so well. Bumpers make a BIG difference. I did some "Crayola CAD" on the geometry of it, and I can't find a way to avoid A LOT of compression on the ball during the point at which it goes over the bumpers, while still maintaining good contact and forward reach when the ball is on the ground. Any ideas there? Maybe we'll be okay with a 13" gap in the bumpers, which should help some.
Unread 14-01-2014, 00:08
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Interesting question. Just for sake of not popping balls we have been considering rollers instead of wheels. This would allow you to only exert forces on the end of the shaft too.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 14-01-2014, 21:38
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
We found the shaft flexed quite a bit. We were concerned about yielding on a impact or fatigue over time. We created a center strut support in our design. It was just another piece of channel that we sectioned to slide into place.
This provide seemingly sufficient support and significantly reduced our concerns. This could have just as easily been 2 off center supports to further alleviate concerns.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 14-01-2014, 00:32
jlian's Avatar
AKA: John Lian
FRC #4955 (LA Tech)
Rookie Year: 2014
Can someone help me on these?
  #15   Spotlight this post!
Unread 14-01-2014, 00:09
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I would not recommend using the churro tube for sure, it's not designed for such stresses.
I feel like anything that would bend a steel hex shaft, even 1/2 inch means you are over compressing the ball and I'd be concerned about popping it. We bent what I think was brass today when we over compressed on one of our prototypes.
Also gonna throw out there that the banebots wheels are insanely good at gripping this ball. In my, walk around the shop and touch stuff to the ball, they were by far the best. Didn't have any VEXpro wheels around though, I've heard good things about them as well.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
