What could go wrong?
What do you predict will be the number one thing that teams will fail to prepare for or underestimate that will cause a lot of trouble at competition? In 2013 it could be loading frisbees from the human player. In 2012 it would be a team's bridge lowering mechanism.
Re: What could go wrong?
Defense. Unprepared teams can get completely shut down if they are up against a solid defense.
Corralling bouncing balls or ground-loading.
I'm seeing a bunch of catapults on social media, but no one is glorifying their floor pickup/loading method. One must get a ball before one can shoot a ball. |
What do you think the best thing a team can do to prepare for intense defense? Last edited by bs7280 : 01-14-2014 at 12:34 AM. Reason: forgot to add quote |
Autonomous.
Teams are going to neglect the importance of having an accurate auton, not use the appropriate amount of sensors to ensure they are consistent, and then insist that they preload a ball and shoot every match. Then, when they miss, it is the burden of their alliance to get their ball into the goal before the cycles can start happening. |
Driver practice, Driver practice, Driver practice
I think the movement of the ball is going to be very strange and will take drivers a while to get used to, and could get caught off guard by other bots in the way. Communication between alliance partners is going to be interesting. I wonder if it will be a relay between coach to drivers or if entire teams will be talking at the same time to get objectives done. |
And to elaborate on that, one thing you can do is get an old skid/tank robot you might have sitting around and have someone drive it against the new robot.
The drive team might complain about the defensive bot's driver knowing their robot too well, or what they're trying to do, but it's practice for a reason. It will only force them to get better. |
That's a lot of batteries.
#11
It won't be a robot issue.
It'll be a communication and strategy issue with their partners. It's hard to get people on the same page in a ten minute period. |
#12
This. I also hope egos don't get in the way, but.... it could happen.
#13
"We need you to play defence."
"But we need assists!" "We can make up the difference." "But we need assists!" "You guys are far more valuable as a defender" "But we need assists!" "You cause more penalties than you score points." "But we need assists!" Can't wait for these conversations... -Nick |
#14
The secret endgame!
#15
Damage.
Most teams seem to be following the Ri3D approachs, all of which have vital assemblies spending time outside the protection of the frame perimeter. Ask yourself if your pickup/shooter/catcher is going to function after a solid hit at speed. Make things robust and easily repaired/replaced. Bring plenty of spare materials. Avoid difficult to fabricate (or obtain for COTS) items. |
