Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 14-01-2014, 09:51
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
Rookie Year: 2011
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
Circular Bumpers
Okay so we are doing a circular base. But one roadblock we have is how to do the bumpers.
Per R-21A the bumpers must be backed by plywood, but this would be difficult on a circle.
I know some teams did this last year, so any suggestions/input? Thanks!!
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 14-01-2014, 10:01
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Circular Bumpers
I'm going to assume that your team chose the circular base for valid reasons, ones which overcome the multiple other reasons why a square or rectangular base would be significantly easier to construct; bumpers being one of many I can think of. Would you mind articulating some of your reasons?
If you're absolutely set on the round base, I think it is more likely that your frame will be constructed as a decagon or other polyhedron. You will just need to cut plywood pieces to fit each side, with a matching angle, and put the pieces together with brackets (which you will probably need to manufacture or modify).
Unread 14-01-2014, 10:02
mrnoble's Avatar
teacher/coach
Team Role: Coach
By the way, loved your wheeled shooter prototype! Very inspiring.
Unread 14-01-2014, 10:04
FilthyArgonian's Avatar
FilthyArgonian FilthyArgonian is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
Team Role: CAD
Rookie Year: 2011
FilthyArgonian is an unknown quantity at this point
You could modify your frame to be hexagonal or octagonal, which would make bumper fabrication exponentially easier. or you could find a way to bend your plywood into a perfect circle.
Unread 14-01-2014, 10:22
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
While use of a steambox and a form to shape the bumper plywood into the appropriate diameter circle, that seems be a significant amount of work even before dealing with pool noodles and fabric.
Given the right expertise and equipment this is certainly doable, can't say I would recommend it though.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 14-01-2014, 10:36
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
While I can't comment on the merits of this specific team, a circular robot frame allows the maximum area inside the perimeter limits, which also allows the maximum area for a catcher.
Soaking the plywood in water overnight and then clamping it to a form and allowing it to dry would be a way to construct the curved plywood. Pool noodles and fabric are flexible, though attaching would still require some work (think attaching fabric on a round seat cushion)
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 14-01-2014, 10:43
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
You could vacuum-form your bumper backing around a cylindrical mandrel. You'd have to build it one ply at a time, up to the full thickness.
Unread 14-01-2014, 11:02
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
Rookie Year: 2007
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
IMO with the 20" extension rule this year I don't think there is much gained by building a round robot just to maximize the catcher. Just doing some quick math I got that a round robot could have up to 4492.6 inches sq to catch in, and a square robot would have 4280 inches sq. That 5% may make the difference but I doubt it. You're losing 2 inches of reach in the corners and gaining 3.8 inches of reach on the edges if building round over square. Hopefully your 6 foot wide catcher will do just fine without those few inches.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 14-01-2014, 11:14
brrian27's Avatar
the Mormon
AKA: Brian
Rookie Year: 2011
Thanks for the tips everyone!
A circular base is pretty important to certain factors in our design. But perhaps we can make it hexagonal or octagonal, or figure out bending the plywood.
team2383.com
Unread 14-01-2014, 11:22
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
You could try bending thinner plywood, like 1/4", and glue it together around a form.
There is also a bendable plywood, called 'wigglewood' but I'm not sure it has the strength needed for bumpers. http://www.woodworkerssource.com/mm5...y_Code=plywood
Unread 14-01-2014, 11:30
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
The wood on the bumper backing is required to be 3/4" thick. It can't be any other thickness, or you will not be allowed to compete. This caused us a lot of difficulty at comps last year.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 14-01-2014, 11:56
I said glue it together, but should have been more specific. Glue up 3 layers of 1/4", or 2 layers of the 3/8" wigglewood. Both should be bendable in the radius required.
Unread 14-01-2014, 12:33
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
The team that had a round robot in our area last season laminated their own bent plywood. I think they used 1/8" so it was easier to bend, more likely to hold its shape and was most like commercially available 3/4" plywood with is usually 5-7 ply. If you really want it replicate commercially available plywood and its strength don't forget to alternate the direction of the grain.
I believe they did their bumpers as two semi circles to make it easier to build and handle.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 14-01-2014, 11:19
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
You could cut out a number of 3/4in thick arcs from plywood and glue them on top of each other to make your bumper backer.
Similar to how this furniture is made: http://inhabitat.com/images/sande.jpg
A CNC router would be a big plus here.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #15   Spotlight this post!
Unread 14-01-2014, 11:43
MechEng83's Avatar
AKA: Mr. Cool
Team Role: Coach
Rookie Year: 2011
I didn't say it was worth the trouble
Red Alert Robotics
