Go to Post When there appears to be something stupid wrong with a game (HPs outscoring robots, unreliable loading, autonomous that accomplishes nothing) I shouldn't complain about it. I should see it as a challenge to exploit! - Chris is me [more]
Unread 14-01-2014, 11:00
Barti Barti is offline
FRC #1382
Barti is an unknown quantity at this point
Post LabVIEW doubt !!
How can I program a Vex Ultrasonic Range Finder (sensor) in LabVIEW??
Unread 14-01-2014, 11:29
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: LabVIEW doubt !!
I think it would be easier to use a different ultrasonic sensor. You could open it as an analog input and use the analog in VIs to pull values from it.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 14-01-2014, 11:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Start with the Ultrasonic example in LabVIEW. The Vex sensor is nearly identical to an SRF04 ultrasonic rangefinder. The wiring and programming is the same. (There might be different timing; I do not know for sure.)
