Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
Unread 14-01-2014, 11:32
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
Rookie Year: 2007
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Applying the JVN calculator using multiple motors and Mecanum
I'm trying to apply the JVN calculator on an 8" mecanum wheel using both a CIM and mini CIM at each wheel and I have a few questions.
1) Can you just add the stall currents together for the CIM and mini CIM and use that number as if it were 1 motor or will that not work?
2) It says that Max Tractive force is 100.3lbs which would be weight*CoF*carpet efficiency=154*.7*.93 = 100.3lb. Does this mean any more pushing force than this will be lost to slipping? (I think the answer is yes but then that leads me to question 3)
3) We had looked at direct driving the 8" wheels using the Toughbox Nanotubes with two 50 to 14 gear reductions. Is the equation for max pushing force = (CIM stall torque) * (# of CIMS) * (gear ratio 1) * (gear ratio 2) * (gear train efficiency) * (coefficient of friction) * (carpet efficiency) / (wheel size)? If so just using 1 CIM on each would yield
(21.5 in*lbs) * (4) * (50/14) * (50/14) * (0.9) * (0.7) * (0.93) / (4 in) = 160 lbs which is more than our Max Tractive force. That leads me to believe we should be gearing it higher if using 1 CIM, and gearing it much higher if we planned on using a CIM and Mini CIM together.
I'm not positive I've got all the numbers right so if someone could double check that or tell me I'm completely wrong (either way is fine) that would be a lot of help. Thanks
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 14-01-2014, 12:08
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Applying the JVN calculator using multiple motors and Mecanum
The stall torque of the combination is the sum of the individual stall torques.
The stall current of the combination is the sum of the individual stall currents.
But the free speed of the combination is not as simple. Follow the link in this post for the formula for free speed:
http://www.chiefdelphi.com/forums/sh...8&postcount=64
Note: since the free speeds of the CIM and miniCIM are so close, the free speed of the combination will be roughly the average of the two.
Unread 14-01-2014, 12:33
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
One can put, for example, an 11 tooth pinion on the Mini-CIM and a 12 tooth on the CIM to even out the speeds a bit. Then you have to adjust for that in the math before you combine them. If you're saying the pinion gear is a 12 tooth in your gear ratio math, Multiply the Mini-CIM's stall torque by 12/11 and its free speed by 11/12 before combining them with the CIM stall torque and free speed.
Unread 14-01-2014, 12:59
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
From my experience, the motors actually seem to run a bit better with the same pinion on each motor. Matching the free speeds is less essential than common wisdom would have you believe - at operating speeds / torques the motors match quite well with the same gear ratio.
Unread 14-01-2014, 13:09
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
For a simplistic, proof of concept ballpark, you could run the spreadsheet with two CIMS, then two minis, and average the results.
Our last experience of combining motors was with 1CIM+1 775(with cimulator) per trans, worked well. I'd agree with Chris above. We considered testing and programming different values to the two motors, but in the end just sent them the same values.
Unread 14-01-2014, 13:28
Ether's Avatar
Rookie Year: 1969
Yes. True for the CIM and mini CIM.
But to be clear, it's not true for motors with substantially different free speeds: the higher-speed motor may be at risk of overheating.
Unread 14-01-2014, 13:53
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Paul Coipoli did write a spreadsheet with the motor combination equations in the thread that Ether linked earlier:
http://www.fightingpi.org/Resources/...culations.xlsm
His MSC seminar also discusses the topic (link skips straight to the motor combining section): http://www.youtube.com/watch?feature...xpYnqJ8#t=1479
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 15-01-2014, 16:25
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
It seems that question (1) has been definitively answered. Add the stall currents together to get the stall current of the 2-motor system.
I am curious about questions (2) and (3) though. Is that the value of CoF that is needed for this problem? On the AndyMark website, the forward/backward CoF is listed as 0.7 for mecanum wheels. Is that implied to be on FRC carpet? None of the plaction wheels have static CoFs listed, but all of the Rubber Treaded Wheels do.
If 0.7 is correct, and if you are not worried about drawing too much current, I think that you should gear it to be faster since you're not gaining any more pushing power.
On the same topic, does this mean that the max pushing force of ANY normal (i.e. with wheels) robot is ~155 pounds, assuming 155 lb robot, 0.93 carpet efficiency, and 1.07 CoF? I understand that many teams use their low gear so that their robot does not draw too much current, but having that upper bound on pushing ability is interesting.
Unread 15-01-2014, 16:37
Ether's Avatar
Rookie Year: 1969
Originally Posted by inkling16 View Post
...assuming 155 lb robot, 0.93 carpet efficiency, and 1.07 CoF?...
To avoid misunderstanding, what does "carpet efficiency" refer to in this context?
Unread 16-01-2014, 10:59
pntbll1313's Avatar
AKA: Pete
Rookie Year: 2007
In my head that number was from rolling resistance because of carpet compression, but that shouldn't affect max tractive fore then should it? Maybe it wasn't supposed to be in that calculation. I found it in another paper too called wheel/floor efficiency http://www.chiefdelphi.com/media/papers/2750
Does that mean both of my calculations in parts 2 and 3 of my question are wrong?
2007 (driver)
Unread 16-01-2014, 11:47
Ether's Avatar
Rookie Year: 1969
In my head that number was from rolling resistance because of carpet compression...
That would have been my first guess. But I prefer not to guess. I'm trying to trace the etymology of the phrase back to its source.
I did a quick search of both documents there and couldn't find it. Does anyone know: Who coined that phrase, and when and where? And in practical application, how is it supposed to be different from the widely used term "rolling resistance"?
In the drivetrain acceleration model located here,
rolling resistance is modeled with a constant parameter Kro and a speed-dependent parameter Krv.
Unread 16-01-2014, 12:02
pntbll1313's Avatar
AKA: Pete
Rookie Year: 2007
That .93 number is straight from the JVN spreadsheet. It is discussed here but again the OP in this thread is not entirely sure where it came from.
Right now I have a 0.85 gearbox efficiency and a 0.93 carpet to wheel efficiency built into the spreadsheet. What other terms eat up power and slow down the robot? I lifted that 0.93 directly from JVN’s spreadsheet, and I have no idea if it’s anywhere close to a realistic number.
http://www.chiefdelphi.com/forums/sh...d.php?t=110382
2007 (driver)
Unread 15-01-2014, 16:54
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
I am very confident in the combination equations in this spreadsheet. I developed it for the exact same reason the OP asked the question. These combinations and current draw calculations match up very well with my multiple motor dynomometer testing.
It does 2 and 3 motor gearboxes and also allows you to take a snapshot at any particular speed condition. One other subtle thing it does is allow you to put your entire gearbox gear ratio into the input section so the combined motor equation is your actual gearbox output equation.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
