Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Unread 14-01-2014, 12:47
TenaciousDrones's Avatar
TenaciousDrones TenaciousDrones is offline
FRC Team 4780
FRC #4780 (The Tenacious Drones)
Rookie Year: 2012
TenaciousDrones is an unknown quantity at this point
4 motors, 2 motor controllers?
Hey guys my team was wondering if we are able to hook two motors up to the AndyMark Toughbox Mini and just controll them both from one Victor motorcontroller.
Unread 14-01-2014, 12:53
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: 4 motors, 2 motor controllers?
Depends on what motors. Read the Game manual, Rule 4.8.21 R51 Table 4-4.
Unread 14-01-2014, 12:54
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
If you're talking CIM Motors, then no. See R51.
The correct way to drive 2 motors and keep them in sync is to split the PWM signal using a PWM splitter. You should have recieved 2 in your kickoff kit.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 14-01-2014, 14:28
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
I think they just wanted to save on the cost of 2 Victors/talons/jaguars
Unread 14-01-2014, 22:16
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Team Role: Mechanical
Rookie Year: 2010
Rynocorn is on a distinguished road
Question: if you are using the KOP tough box mini and both the motors on one sides are linked together by the PWM splitter, won't they be turning in the same direction? Because the gearbox needs one clockwise and the other counterclockwise in order to work? I assume I am missing something as lots of teams must use them...
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 14-01-2014, 22:20
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
You can reverse the direction of a DC motor by swapping the polarity of the power leads.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-01-2014, 22:24
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
No, they both spin in the same direction
(see attachment)
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 14-01-2014, 22:28
Rynocorn's Avatar
AKA: Ryan Jacobs
Rookie Year: 2010
(see attachment)
Ohh my.... Well I guess we happened to accidentally invert the power leads on two of our victors and then have the code work perfectly with a motor inverted on each side. I am feeling pretty dumb right now
Thanks you guys
Unread 15-01-2014, 01:12
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Thanks you guys
Don't feel too bad, this same thing threw me off a few days ago while we were troubleshooting a testing robot we have. I'm still used to some of our older gearboxes that did require you to reverse the direction of one motor.
Unread 14-01-2014, 22:26
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
The 2 motors that feed the toughbox are supposed to turn in the same direction. I.e. both counter clockwise or both clockwise.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
