Re: SFX (SmartDashboard 2.0) with Driver Station
Java 7 Update 45 (64-bit) Java SE Development Kit 7 Update 45 (64-bit) Java(TM) 6 Update 24 I believe they were just recently downloaded with Netbeans 7.4, though I was not the one to set it up. There shouldn't be anything hidden. We recently reset the computer to factory default settings so there shouldn't be any weird software from a long time ago installed that I'm forgetting about. Also, I just tried referencing SmartDashboard and running that code, and it didn't make a difference. |
Well I went ahead and did it and it works! SFX now opens with Driver Station!
Note to the developer: maybe add that to the documentation? And thanks to all the help! |
So you uninstalled Java 6 correct? odd that there is no error message...
I uninstalled Java 6 and Java 7 Update 45. And yes, I found it strange that it didn't throw an error (which I have seen happen) and I was able to open it in every other way.
This works for me:
Putting this line into the FRC DS Data Storage.ini works for me - I have to switch to Java then back to default to launch it. Also it takes a second for it to show up. DashboardCmdLine = "C:\\apps\\jdk1.7.0_51\\bin\\java.exe -jar c:\\SFX\\sfx.jar" Things to know: 1: I installed java to the directory above so modify accordingly 2: I copied sfx.jar and plugins to a new directory called SFX right off the root of the C: drive. |
