Go to Post John Abele certainly deserves much more recognition than he gets. - Richard Wallace [more]
Unread 14-01-2014, 20:11
ROULT ROULT is offline
AKA: pepemanboy
FRC #4403 (ROULT)
Rookie Year: 2013
ROULT is an unknown quantity at this point
4 motor arcade drive CAN Jaguar (Java)
Hi, everybody...
Our team (4403) is using 2 motors in each gearbox of the AM14U Chassis.
We are also using Jaguars connected to each other with CAN.
We are programming in Java.
Is it possible to use 4 jaguars in CAN to control the Arcade Drive in Java?
Unread 14-01-2014, 20:21
Thorn Thorn is offline
None #2869 (Regal Eagles)
Team Role: Teacher
Rookie Year: 2012
Thorn is an unknown quantity at this point
Re: 4 motor arcade drive CAN Jaguar (Java)
Are you using the built in Robot Drive class?
If 2 motors connect to one gearbox, they are just working together for more power?
Unread 15-01-2014, 10:29
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Assuming you are using %volts mode, it is equivalent to driving it with a PWM Y-cable and is very doable. Simply send the same command to each jaguar on the same side of the tank (four commands instead of two). Theoretically, you would need to put them into a group and then send an additional execute group command, but we have not found that to be necessary.
If you are trying to use the PID feature of the jaguar with encoders hooked to the jaguar (as opposed to the cRIO DSC), then things get much more complicated. Teams have had trouble splitting the encoder to go to two jaguars and even if you accomplished the split, you have two servo loops which will fight each other for control of the encoder velocity. Multi-motor PID is much simpler with one controller (cRIO) and then send duplicate commands to the jaguars in %volts mode as above.
