Go to Post Have no fear, ancient and brilliant coaches of yore were consulted. - JamesCH95 [more]
Unread 14-01-2014, 21:57
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
RobotBuilder toggle option?
So I'm using RobotBuilder to generate code for a test robot and I want to toggle a command on and off with a joystick button. There is a method in the command-based code to do this (button->ToggleWhenPressed()) but no option in RobotBuilder. (See attached screenshot.)
Any idea why this is? Is there a way to enable this somehow?
Unread 15-01-2014, 10:07
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: RobotBuilder toggle option?
I believe you can simply select "When Pressed" and build the toggle into the command.
Unread 15-01-2014, 10:28
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
We might be able to get that enabled in RobotBuilder, but in the mean time, you can edit the whenPressed() method to be toggleWhenPressed() in the generated code. Just be sure to do it outside of the //BEGIN //END generated code comments.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 15-01-2014, 18:44
bvisness's Avatar
Rookie Year: 2010
If you could work that into RobotBuilder I would be incredibly happy. In the meantime, that's exactly what I've done - moved it outside the comments and modified it. Thanks for your help!
