Go to Post The ever popular Safety Tip Of The Day: Do Not Lick Wheel While In Motion The other popular one was: Remember Stupid Hurts - Joe J. [more]
Unread 15-01-2014, 01:12
Dragonslayerend Dragonslayerend is offline
DuncanDynamics lead programmer
AKA: Tom Xiong
FRC #3970 (DuncanDynamics)
Rookie Year: 2012
Dragonslayerend will become famous soon enoughDragonslayerend will become famous soon enough
COTS Closed loop systems
In the rules it states any COTS closed loop system (gas shocks) are not considered pneumatics and therefore not under pneumatic rules. So to bypass the 60 PSI working regulation, we wanted to just pump 120 psi of air into a cylinder and use it as a gas shock and lock it off so no solenoids are controlling it. Will this mean it's no longer a pneumatic system and now labeled as a gas shock? This will be used for our catapult system, not that we are going with this, we are actually going with workout bands, but this is something we've prototype and found to work well.
Unread 15-01-2014, 01:54
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: COTS Closed loop systems
It's NOT COTS, whatever else it may be.
Which means that you're going to have to ask the GDC if a closed-loop gas system that isn't COTS is also not a pneumatic item, even if built from pneumatic parts.
I've got a feeling that the answer will end up being "no".
Technically, as well, there's an issue: Leak-proofing. With that tubing, you're probably going to have a few leaks.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-01-2014, 07:18
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Not being an Inspector, I would have to say that an air cylinder is always an air cylinder and is intended to be an open-loop system by design. A gas shock is a device that is designed and sold to be a closed-loop system. The air cylinder would not survive the loading and cycles, especially starting at 120 psi...
Mathy stuff...
* Assuming a 4" stroke cylinder
* Half Extended with 120 PSI on either side & plugged
compression of 1" = 240 psi (2" goes to 1", doubling the pressure) on the extension side and 80 psi (2" goes to 3", dropping the pressure by 1/3) on the retraction side
compression of 1.5" = 480 psi (1" goes to 1/2", doubling the pressure) on the extension side and 68.6 psi (original 2" goes to 3.5", dropping the pressure by 43%)
Most cylinders have a burst pressure that you will quickly exceed.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
