Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 15-01-2014, 10:08
3montyjack 3montyjack is offline
FRC #4500
3montyjack is an unknown quantity at this point
2 Pneumatic cylinders on one solenoid.
Our team is planning on lifting its arm with two pneumatic cylinders. It would be a lot easier to put two cylinders on one solenoid. Can you put two pneumatic cylinders on one solenoid?
Unread 15-01-2014, 10:11
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Re: 2 Pneumatic cylinders on one solenoid.
Yes, we do it all the time. We have run a couple cylinders off the same solenoid for several robots. It is great for symmetric applications.
Unread 15-01-2014, 10:23
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
To paraphrase a common answer from the GDC: There is no rule that explicitly forbids this.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 27-01-2014, 19:32
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Can you elaborate on how you ran 2 cylinders off the same solenoid? We are needing to do this and was not sure the best way.
Thank you for your help!
Unread 27-01-2014, 19:37
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Put a 'T' or 'Y' connection on the output of the solenoid. Have one tube go to each cylinder. Be sure to have the same length of tubing going to each cylinder if you want each to activate at the same time.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 27-01-2014, 19:38
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
You put a t-fitting on the output of the solenoid to branch the lines to both of the actuators.
Code:
Solenoid Valve
A      B------------
|   Actuator 1     |
T---------A     B--T
|   Actuator 2     |
----------A     B---
Unread 27-01-2014, 20:06
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
To run two cylinders from one solenoid all you need to do is take the lines that go from the solenoid to the cylinder and put a Y coupler (Link Posted) on each one. This now gives you two lines from each port on the solenoid that you can use to make the two cylinders you are using act the same or opposite of each other. I hope this helps. http://www.andymark.com/product-p/am-2184.htm
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 27-01-2014, 20:34
FRC #3179
Thumbs up Re: 2 Pneumatic cylinders on one solenoid.
Thank you for the info. We do run them this way on prototypes, but we thought it was in the rules that each cylinder had to have its own solenoid. I went and reread the rules and don't see that stated anywhere.
Unread 27-01-2014, 20:57
Chris_Ely's Avatar
AKA: luckof13
Rookie Year: 2010
You might have been thinking of R90 which states that outputs from multiple solenoid valves cannot be plumbed together. This is different then plumbing multiple cylinders to one valve.
Unread 27-01-2014, 22:18
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Out of curiosity, why do you need to run multiple cylinders from one valve instead of just two separate valves using a closely linked air source?
Unread 27-01-2014, 22:21
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
For anything like a pickup that uses two cylinders to deploy, or shifting drive gearboxes, there is really no reason to use 2 solenoids. Saves space, and more importantly, money.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 27-01-2014, 22:26
Chris_Ely's Avatar
AKA: luckof13
Rookie Year: 2010
If both cylinders do the same thing, then there is no need for two valves. Two valves in this case would be more complex, requiring more slots on the breakout, more wiring, and more code. Using on valve in this case also eliminates the chance that one cylinder doesn't actuate.
Unread 28-01-2014, 07:21
protoserge's Avatar
If you are planning on shooting with two actuators, it may be in your interest to use two solenoid valves. The reason is that the air flow rate is divided in half when firing two actuators with one solenoid valve versus one actuator per solenoid valve. The lower air flow rate would result in a slower actuation.
Unread 28-01-2014, 10:33
If you don't have a need for the two valves, you could likely do away with the second piston, too.
Saving more complexity, weight and money.
The comment about shifting gearboxes makes tons of sense though. That's definitely one where you want either both or neither to fail together, lest you drive in circles for eternity
  #15   Spotlight this post!
Unread 28-01-2014, 11:03
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
the pneumatics downstream of the primary regulator that get's set to 60PSI are of no significant concern for inspection.
also solenoid valves are like $75 each, just use one if you can
