Go to Post Indianagineers! (n.: In-di-ae-nah-jih-nir: any resident of Gary, Indiana, or it's suburbs, who is trained in the use or design of machines or engines, or in other areas such as electrical or chemical technology) - dlavery [more]
Unread 15-01-2014, 12:30
S1nus S1nus is offline
FRC #1757
S1nus is an unknown quantity at this point
Possible bug?
I was setting up a four-motor drive train (with jaguars) recently, and made sure the ports were correct and all of the hardware was right (it was). However, when I drove it forward, the jaguars controlling the two left-most motors lit up red, signifying that they were going 'backwards'. They were going in the correct direction, but normally when we set up drive trains like this, they flash green because they know that the direction they're turning in is actually forward.
Those two motors only spun at half speed, and I assumed this was because jaguars can't go full speed in reverse, so to fix it I did setInvertedMotor(...), and flipped the polarity of the motor which it was connected to. That did the job.
Could this be a bug in the new wpilib distribution?
