Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 16-01-2014, 09:55
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
VEXPro Out of Stock
VexPro seems to be going out of stock of some items. Specifically hex shaft stock and maybe some versa planetary parts?
Any other sources to get hex shaft besides AndyMark and VexPro
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 16-01-2014, 09:58
thinker&planner thinker&planner is offline
AKA: CAAAAAD
Team Role: Mechanical
Rookie Year: 2013
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Re: VEXPro Out of Stock
McMaster Carr is your friend for all things mechanical:
http://www.mcmaster.com/#aluminum-hex-bars/=q9yech
Also Metals Depot:
https://www.metalsdepot.com/index.php
Hope that helps
(the 2024 alloy is probably best, besides 7075, which is not available on McMaster)
Unread 16-01-2014, 09:59
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Most metal suppliers should carry 1/2" steel hex shaft/bar. The tolerancing may not be identical to that used by Vexpro or Andymark hex products, though.
Unread 16-01-2014, 10:02
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
It's usually pretty bad. I have a lot of not so fond memories of sanding down McMaster "1/2" hex shaft to fit. If you really don't want to wait for Vex Pro or WCP, Churo Tube from AM is probably your best bet.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 16-01-2014, 10:04
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
Be careful when you buy hex stock from McMaster Carr though, You want to get slip fit stock (like what you find from Vex Pro). The raw stock that you buy on McMaster is not a slip on tolerance, and will not fit well with your Vex couplings, spacers, and collars. The Vex hex stock our team has purchased is extruded and seems to arrive slightly bent. We will be looking at other options in the future.
Unread 16-01-2014, 10:29
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
All of the Versaplanetary parts are in stock, except the dual motor input. That will be back in stock and shipping next week.
There are two versions of the hex stock, 3' and 18". The 3' length is temporarily out of stock, but the 18" version is still in stock. The 18" version holds a tighter straightness tolerance than the 3' version so if you do not need the length, then I recommend the 18" length.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 16-01-2014, 11:15
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
It's been a very interesting two weeks guessing at what will come in the next package from VexPro
We've gotten 5 packages so far, with another 2 recently shipped.
I absolutely love VexPro, it's just a bit unfortunate for us because we, as a team, have decided to purchase (essentially) all of our parts from VexPro this year because of the huge selection - from the VersaChassis to WCD gearboxes to gussets and VersaPlanetaries and more, spending 40% of our budget this year - and we're very confused as to what's going on.
I wish the products were in-stock better given that they really only need to be super-well stocked for 6 weeks out of 52, but at the same time understand the logistical difficulties of coordinating expected demand and then dealing with the actuality.
Just wish we had a drivetrain by now
Anyways, thanks to the VexPro team for how they've been handling it - we've noticed two of our packages shipped 2nd day versus ground - and we understand that some things (manufacturing) are at this point out of your hands.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 16-01-2014, 11:22
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Order the 18in for what you need if you need it now. I placed our order on Tuesday and ordered the 18in stock so we can make the drive axles we need now and we can wait for the 3ft stock to come in.
The package just arrived on my desk along with hex bearings, collars, chain, etc. While a lot of Vex/WCP is out of stock for various reasons you can't beat their shipping! I've had orders out the door within 1-2 hours of placing the order.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 16-01-2014, 12:28
Rookie Year: 2000
All of us at VEX are distraught about the product availability timing this year for VEXpro. Some things were definitely out of our control, but most were completely within our control.
We made forecasting and planning decisions based on last year and based on how useful we thought each product was going to be (btw, not at all knowing what the game is ahead of time) for the upcoming season. We got way too many things wrong this year, but I can promise these two things: (1) We will do whatever we can to make it right this season and (2) we WILL be much, much better next year.
Again, I apologize for the delays and please work directly with our sales team for your specific shipping issues. You can call at 903-453-0802 or e-mail at sales<at>vexrobotics.com.
Paul
Unread 16-01-2014, 12:39
ksafin's Avatar
AKA: Kirill Safin
Rookie Year: 2012
Paul,
Thanks for your honesty and straightforwardness.
It's really a pleasure to deal with a company that recognizes and acknowledges it's own mistakes and promises to own up to them.
Which is part of the reason we put in another VexPro order a few days ago, and are putting in another one today or tomorrow despite the delays and shortcomings in supply stock. (It's too hard to resist buying this stuff - you guys have some really amazing products!)
Thank you for the work you and the VexPro team are currently undergoing to get things back on track - we look forward to getting our packages from VexPro in the coming week!
Unread 16-01-2014, 12:48
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
As an aside, we have found that the CAD files of the vex parts have made 3D printing a breeze. We have printed out gussets etc. which have allowed us to move forward with pre-production of our practice bot. We know it won't stand up to much, but we can replace them when the real stuff arrives.
Unread 16-01-2014, 12:51
ksafin's Avatar
AKA: Kirill Safin
Rookie Year: 2012
By the way, where can the stand-offs used in the various gussets be purchased?
Unread 16-01-2014, 12:55
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
They are standard VEX standoffs, so just wander over the VEX site, I'll try and get the link on the gussets page.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 16-01-2014, 16:41
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Paul
Paul,
I hope that one day soon, the stakeholders of the GDC and FIRST will unveil more details of the game to suppliers, in order to achieve better forecasting of specific parts that might sell more than others.
As with any company, having an excess of inventory isnt always good and bottom line, teams cant get what they need in such a time crucial project for high demand items.
Personally, our biggest issue has always been pneumatic cylinders. Its an expensive item to stock up on in different sizes. Its not like we are the Robonauts that carry 100's of cylinders in their stock bin ready for use.
-Glenn
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
  #15   Spotlight this post!
Unread 16-01-2014, 23:36
ksafin's Avatar
AKA: Kirill Safin
Rookie Year: 2012
For anyone else on the VexPro Team -
After the new shipments come in next week, will you be stocked for the rest of the season? Or will sporadic shipments continue?
I ask because we'll very likely have to order more VersaChassis gussets and channels and I wanted to know if they'll be in stock (and we'll be able to order on-demand) or if we need to order in advance in order to "get in line".
