Re: VEXPro Out of Stock
VexPro was able to just give us two 18" shafts and adjust the total cost very easily.
Thanks VexPro! |
Hey Paul, is there any word as to what the lead times might be for the out of stock Dog gears?
Just for the record, we had an order that included VersaFrame 1" x 1" ship on Friday -- we'd only ordered it on Wednesday evening and were pleasantly surprised since the website had indicated this was delayed. Thanks!!!
At the bottom of the product page
The undersized Vex hex stock is probably my favorite product that Vex offers. Seriously saves us many, many hours milling the faces of hex shafts down to size. |
Temper 0 (Annealed) <-- machinable Width 1/2 inches Width Tolerance +0/-0.004 inches <-- will determine fit to hole Overall Length 36 inches Length Tolerance +0.032/-0 inches Indentation Hardness 83 Rockwell B Tensile Strength Max 89900 PSI |
#10
Our team has CADed our own versa plates, they can be fabricated with a CNC, laser cutter, or (if you somehow have access to one) a metal sintering 3D printer. The .zip I attached has a PDF drawing and a STEP file.
#11
For items marked "out of stock" will there be a re-stock? or should we make other plans?
The main thing I am interested in is the dual motor input for the versaplanetary (217-3141) |
#12
The VP dual input, Cimile housings and 3 Stage Ball Shifter housings are all on the same trailer. We have all the kits sitting waiting for the housings to arrive. We expect them to arrive tomorrow. If they do, we will ship all current orders on Wednesday and should put them back in stock Thursday evening. Paul |
#13
Thanks for the update and the reason why those items are on hold. Just glad to hear 3 CIM Ball Shifters are close to shipping. |
#14
Would this shipment happen to have any Versa Hex hubs 1/2" in it? I need those and would prefer to get them from you...
#15
We have just sent 1,500 of the Versahubs with 1/4" bore to a machining house to be bored and broached, but here is the bad news: the only way to get fast turnaround on these part we need to rotary broach. What that means is the hex hole will not be oriented to the Versakey pattern. In my opinion, this does not matter because you only need one Versahub per shaft (see our diagrams on the product page). However, that is the best we have at the moment. We are contacting customers with current orders to notify them that their hex hubs will not be oriented to the Versakey pattern. We know this situation sucks, but I feel it is better than just staying unavailable. |
