Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 16-01-2014, 10:28
GuyM142's Avatar
GuyM142 GuyM142 is online now
AKA: Guy
FRC #3339 (BumbleBee)
Rookie Year: 2012
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Moving a motor at specified power
Is there a sensor so I can use to control the power of the motor? (Instead of voltage from -1 to 1)
I want to move an arm with specified power so that the battery condition won't affect the power of it.
I know how to do it with speed control (like last year's shooters) but this is totally different.
Unread 19-01-2014, 01:01
GuyM142's Avatar
AKA: Guy
Rookie Year: 2012
Originally Posted by Alan Anderson View Post
Depending on the underlying reason for your requirement, there might be another appropriate answer. Why do you want a specific power for your arm, rather than a specific speed?
It doesnt have enough time to accelerate necause it works for half a second or less each time.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 19-01-2014, 01:11
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: Moving a motor at specified power
When the motor is run at full voltage (1.0 or -1.0) for the duration required, it doesn't have enough time to accelerate?
If that is the case, then you need to address your problem with a mechanical solution (gearing?) to provide the acceleration desired given your motor's spec.s and the load it is driving.
http://team2168.org
Unread 24-01-2014, 09:40
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Agreed. If your system can not provide enough peak power, any closed loop system will simply stay at that peak and still be limited by the battery. A servo does not create power that is not there, it controls the application of the power. Re-evaluate your motors and/or gearing.
Unread 16-01-2014, 13:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
