Go to Post My friend Noah said he talked to someone that knew me from Chiefdelphi. That's just creepy. - Adam Y. [more]
  #16   Spotlight this post!
Unread 16-01-2014, 22:55
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
Re: Mecanum Wheels - How do they work?
Originally Posted by Ether View Post
There's no kinematic reason why mec needs to be square in order to rotate properly.
Quickly sketching the vectors on a napkin, it looks like to me that wheels in a square will optimize spinning (maximize total torque on robot) for a particular wheel distance d from center of robot; perhaps you could comment? The other quick example I could think of is if the wheels were in a line. Then the total torque about center is 4*|F||d|*root(2)/2, versus 4*|F||d| with the wheels in a square.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #17   Spotlight this post!
Unread 17-01-2014, 14:49
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by AGPapa View Post
... The left joystick controls forward-back and strafing. The right joystick does turning.
Our team did fairly well with a mecanum drive a few years ago. Instead of two joysticks, we used just one 3-axis joystick, such that twisting the handle controlled rotation of the robot. It was so intuitive that anybody could pick it up pretty well.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #18   Spotlight this post!
Unread 17-01-2014, 16:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
A more likely cause is that the rectangular bot had poorer weight distribution or the frame wasn't flexible enough to keep traction on all 4 wheels or the rollers were binding. There's no kinematic reason why mec needs to be square in order to rotate properly.
Let's consider the ideal case first, in order to understand the physics: mec wheels with no roller friction and no roller axial or radial free play; floor surface is non-compliant (ignore carpet compression and stretching).
Refer to attached sketch
First, the kinematics (ideal):
Let P be the perimeter of the rectangle formed by the centers of the 4 wheels:
P = 2*(Lwb+Ltw);
Let r be the wheel radius
For a given vehicle rotation speed omega_v (radians/sec) of a vehicle rotating in-place about the center of the aforementioned rectangle (i.e. Vx=0 and Vy=0), the wheel rotational speed omega_w (rad/sec) will be given by
omega_w = (1/r)*K*omega_v .... (see page 7 of my mec kinematics paper)
... where K = (Lwb+Ltw)/2 = P/4;
solving for omega_v and substituting for K:
omega_v = (1/K)*r*omega_w = (4/P)*r*omega_w;
So you can see that the vehicle rotation speed for a given wheel rotational speed, is the same for all rectangles with the same perimeter.
Now, the forces and torques (ideal):
wheel torque: tau;
carpet force component in plane of wheel and floor: Ff = tau/r;
total carpet force in direction of mec roller axis: Fr = Ff*sqrt(2) = (tau/r)*sqrt(2);
Let the ratio f be defined as: f = Ltw/Lwb;
theta = atan(f); .... (see sketch)
alpha = pi/4 - theta;
carpet force component in direction of vehicle rotation: Fv = Fr*cos(alpha) = (tau/r)*sqrt(2)*cos(alpha);
distance from center of rectangle to center of wheel: D = (1/2)*sqrt(Lwb^2+Ltw^2);
P = 2*(Ltw+Lwb) = 2*Lwb*(f+1) => Lwb = (1/2)*(P/(1+f)) & Ltw = f*(1/2)*(P/(1+f));
so D becomes:
D = (1/2)*sqrt(((1/2)*(P/(1+f)))^2+(f*(1/2)*(P/(1+f)))^2);
D = P*sqrt(1+f^2)/(4*(1+f));
torque about center of rectangle: Tv = Fv*D;
Tv = ((tau*sqrt(2))/r)*cos(alpha)*(P*sqrt(1+f^2)/(4*(1+f)));
Tv = ((tau*sqrt(2))/r)*cos(pi/4 - theta)*(P*sqrt(1+f^2)/(4*(1+f)));
Tv = ((tau*sqrt(2))/r)*cos(pi/4 - (atan(f)))*(P*sqrt(1+f^2)/(4*(1+f)));
using:
cos(pi/4-atan(f)) = (1+f)/(sqrt(2)*sqrt(1+f^2));
... Tv simplifies to:
Tv = ((tau*sqrt(2))/r)*((1+f)/(sqrt(2)*sqrt(1+f^2)))*(P*sqrt(1+f^2)/(4*(1+f)));
Tv = (P*tau)/(4*r);
Now that I've done all that trig and algebra, here's a much quicker way:
carpet force component in direction of wheel axis: Fa = tau/r;
torque around center of rectangle:
Tv = (tau/r)*(Ltw/2) + (tau/r)*(Lwb/w) = (tau/r)*(Ltw+Lwb)/2 = (tau/r)*(P/4);
So the torque on the vehicle is the same for all rectangles with the same perimeter.
Now consider the non-ideal case with roller free play, roller friction, and carpet compression and stretching.
This will be an intuitive explanation.
In the case where Ltw >> Lwb (very wide configuration), the fore/aft component of the wheel translational motion is much larger than the strafing component.
In the case where Lwb >> Ltw (very long narrow configuration), the strafing component of the wheel translational motion is much larger than the fore/aft component.
Since a non-ideal mec wheel is considerably less efficient in the strafing direction, you'll see more losses when trying to rotate when Lwb >> Ltw.
Bottom line:
For the small deviations from square typically seen with FRC mec bots, and for properly functioning mec wheels on a frame that's sufficiently flexible to maintain traction on all 4 wheels, the bot should turn fine - and certainly better than a skid-steer with the same dimensions.
  #19   Spotlight this post!
Unread 17-01-2014, 22:15
foote stepped in
AKA: E. Foote
FRC #0868
Setting the frame perimeters equal was an interesting way to look at this (especially since an FRC robot is limited by it). I (and I'm pretty sure the rest of CD) appreciate your time and efforts on the subject.
  #20   Spotlight this post!
Unread 18-01-2014, 00:26
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
+1
This is great stuff.
