Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 16-01-2014, 16:53
Team 1554 Team 1554 is offline
FRC #1554
Team 1554 is an unknown quantity at this point
Pneumatic Solenoid Wiring Conundrum
This year we want to use the McMaster-Carr high flow double solenoids part no. 6124K514 found at http://www.mcmaster.com/#catalog/120/1007/=qa3jr8. In the past, our team has used solenoids that require only two pins of electronic input. The electronic input on these particular solenoids is provided by a DIN connector and requires three pins: a hot, neutral, and ground. How/Where would we connect the three pins to the robot? How is it different from connecting the two pin solenoid electrical input?
Unread 16-01-2014, 17:16
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Did you get the 12VDC version? Hot, neutral and ground are typically used when describing Alternating Current.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 17-01-2014, 13:02
FRC #1554
Re: Pneumatic Solenoid Wiring Conundrum
No, we got the 24V DC version because that was the voltage on last year's solenoids. The lingo was from the video we saw on how to wire the DIN connectors that it needed.
Unread 17-01-2014, 13:55
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
I see there is a 110VAC option for that particular valve and the neutral likely only applies if you are wiring AC.
Unread 17-01-2014, 14:19
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The coil should be marked with the voltage. Assuming it is 24V, i expect 24V would go the H & N. Sometimes coils are polarity sensitive so try both ways. Leave the ground unconnected.
Unread 17-01-2014, 15:12
FRC #1554
That part we understand. The issue is we don't know how to connect the solenoids to the robot once they're all wired up. These solenoids need 3 pins and we don't know if they go to an analogue breakout, the sidecar, or some other device/adapter. The solenoids we usually used only needed 2 pins.
Unread 17-01-2014, 15:36
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Don't use the ground. That leaves two pins for each solenoid. Total of 4. They connect to the solenoid break out just like last year.
Each solenoid gets wired to a separate channel on the break out. It gets programed as two separate solenoids. One is extend, the other retract. It will stay in the position last set. Only energize one solenoid at a time.
Unread 17-01-2014, 16:31
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Yup, don't connect the ground to anything...not even robot body! Use multimeter to check resistance between hot and neutral, you should have continuity with low resistance less than 20ohms (ball park #)
