Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 16-01-2014, 19:44
ducttapewarrior ducttapewarrior is offline
FRC #4608
ducttapewarrior is an unknown quantity at this point
Window Motor Gears?
We want to use a window motor we received through FirstCHOICE and we don't know where to find gearing or way to attach a hex shaft to the output-drive gear.
Any leads or tips would be appreciated
-Team 4608
Unread 16-01-2014, 19:55
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Window Motor Gears?
FIRST Choice had couplers that interfaced with the Denso window motors and could be used either as a hub or a round keyed shaft 5/8" diameter:
http://www.firstchoicebyandymark.com/en/fc14-135
However, they are sold out so I've been 3D printing them for my team to give us the output coupling we need (including hex output as necessary).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 16-01-2014, 20:19
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
I think, I don't have one to check, but I am pretty sure the metal shaft in the middle (if you remove all that plastic) is a 8mm keyed shaft. This would make it identical to a CIM.
If I am not mistaken, and I am pretty sure I am correct, then you can use this hub from AndyMark to interface with the motor
EDIT: Post #2 of this thread from 2011 seems to confirm my thoughts, as the window motors have not changed since then
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 16-01-2014, 21:45
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
Team Role: Leadership
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
If you have a 3D Printer, this could work:
http://www.thingiverse.com/thing:190429
Unread 16-01-2014, 22:19
DonRotolo's Avatar
Back to humble
FRC #0832
Depending on the motor, that shaft may or may not turn. Beware, and observe first.
Unread 17-01-2014, 13:45
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Rookie Year: 2011
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
We got burned by this while working on an off-seasons project. The metal shaft in the center was just an idler, and the plastic piece was being driven by a gear at the base of the gearbox. Live and learn...
Unread 17-01-2014, 23:38
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Also, be aware that window motors have a thermal trip in them to prevent overheating. If you are running it near stall for an extended period of time and it stops working, it may have to cool down a bit.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
