Go to Post I'm not gonna reinvent the wheel cause I can already buy it :) - Stephen Kowski [more]
Unread 17-01-2014, 13:55
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Team Update 1-17-2014
Administrative Manual:
6.10 ENTREPRENEURSHIP AWARD sponsored by Kleiner, Perkins, Caufield & Byers
6.10.2 Guidelines
EXECUTIVE SUMMARY
ORGANIZATIONAL STRUCTURE: Please detail how the team is structured to 1) Raise funds; 2) Ensure funds are properly spent; 3) Find and engage sponsors; 4) Recruit team members/mentors for current & future seasons; 5) Ensure FIRST principles remain core to the team’s efforts. Uploading an image of your team organizational chart below, will also satisfy this requirement.
(1600 characters allowed, including spaces and punctuation. Graphic image allowed in addition to or as an alternative to text - upload 5” x 4” 100 dpi resolution images that end in .JPG or .GIF)
FINANCIAL STATEMENT: Please include information on team finances (include financial statement detailing income and expenditures). Uploading an image of your team financial plan below, will also satisfy this requirement.
(1600 characters allowed, including spaces and punctuation. Graphic image allowed in addition to or as an alternative to text- upload 5” x 4” 100 dpi resolution images that end in .JPG or .GIF)
Game Manual:
Game Manual
Section 2.2.4: VISION TARGETS
The retro-reflective material on the dynamic VISION TARGET is nominally 3¾ in. from the FIELD-side surface of the ALLIANCE WALL polycarbonate sheet above the LOW GOAL.
Section 3.2.3: General Rules
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION:
“carrying” (moving while supporting BALLS in or on the ROBOT),
“herding” (repeated pushing or bumping),
“launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT),
“trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance. If extended, another TECHNICAL FOUL. If strategic, RED CARD for the ALLIANCE.
Section 4.6: BUMPER Rules
R26
In Team Update 2014-01-14:
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame
  • must not be greater than ¼ in. deep or
  • the BUMPER must be backed by the FRAME PERIMETER at least every 8 in wide.
In Manual:
  • must not be greater than ¼ in. deep, and (change to “or” per last TU)
  • not more than 8 in. wide.
Section 5.1: Overview
In the event where order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head Referee during setup for that MATCH. Upon notification, the Head Referee will require ALLIANCES to place their ROBOTS per the following protocol:
Qualification MATCHES
Blue GOALIE (if in use)
Red GOALIE (if in use)
Blue ROBOTS in the White ZONE
Red ROBOTS in the White ZONE
Elimination MATCHES
Lower seed GOALIE (if in use)
Higher seed GOALIE (if in use)
Lower seed ROBOTS in the White ZONE
Higher seed ROBOTS in the White ZONE
Section 6: Glossary
POSSESS: (for a ROBOT) to carry (move while supporting BALLS in or on the ROBOT), herd (repeated pushing or bumping), launch (impel BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT), or trap (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them) a BALL.
Unread 17-01-2014, 13:59
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Team Update 1-17-2014
That really opens up some defensive play.
Unread 17-01-2014, 14:03
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Possessing the opponents ball is still prohibited. Care to explain your thoughts?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 17-01-2014, 14:05
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Hit it.
Unread 17-01-2014, 14:06
Flywheel Police
Originally Posted by AdamHeard View Post
Hit it.
Exactly, you can now plow into their ball once and drive away.
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
The new standard for ground-only (no manipulator) POSSESSION is herding (repeated pushing or bumping) and trapping. If you drive by, and hit the opponents ball away, then drive away, you're good. Basically, if you aren't in control of it after you hit it (once) away, you should be penalty free.
Unread 17-01-2014, 14:07
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I believe the concern was that attempting to deflect an opponents ball (ie a single bump on the ball that sent it in a new, likely desired, direction) could be considered launching and earn a penalty via g12. This update makes it clear that getting in the way like that is legal and does not incur a penalty.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 17-01-2014, 14:28
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
So, if you catch an opponents ball (by mistake - not through any intent on either alliance's part), then you incur a penalty if you keep it, and you incur a penalty if you kick it out of your robot?
Seems to provide a powerful deterrent to an open-topped passive catching design.
Do I have this correct?
- Mr. Van
Coach, Robodox
Unread 17-01-2014, 14:29
Flywheel Police
- Mr. Van
Coach, Robodox
That's the way I always understood the rule, and the update doesn't seem to have changed that.
Unread 17-01-2014, 14:35
markmcgary's Avatar
markmcgary markmcgary is online now
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
I think this update further clarifies POSSESSION as:
So, now there is no doubt that if an opponent ball accidentally landed in your robot and you use a mechanism to remove the ball, you can be penalized.
Unread 17-01-2014, 14:40
Flywheel Police
Technically there is still a loop hole. If you catch the opposing alliance's ball and don't move you have not technically possessed the ball according to the definition.
Unread 17-01-2014, 14:52
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Incorrect. You are "Trapping" the ball
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 17-01-2014, 15:15
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Wrong. If an opponents ball lands in your robot and you stop moving and you were not purposefully catching the ball, then you are not shielding the ball purposefully from the other alliance.
If the other alliance's ball happens to land inside your robot and it was inadvertent, if you stop moving immediately then it would seem that you would not be penalized.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 17-01-2014, 15:24
Flywheel Police
Agreed, I would not consider a ball inside of your robot as trapping. But, I would also not consider this the intent, or even a strategy that should be implemented in any way.
  #15   Spotlight this post!
Unread 17-01-2014, 15:31
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
As the rules are written, I believe you're right.
That being said, I highly doubt the call will be this cut and dry. If you catch a ball, put your hands up in the air, and make it clear to the refs that you did not intend to do it, and you don't want to actively release it, then what happens? Do you sit there for the rest of the match as a black hole? Does the Head Ref make the call to put another ball into play as if your robot died with a ball in it? It's an interesting (and annoying) situation to think about for sure.
If anything, there needs to be some sort of grace period for an unintentional catch, where a machine is given some reasonable amount of time (say 5-10 seconds) to get the ball out of their robot without being penalized - although even that isn't that simple. On paper, there are certain situations where it may make sense for a team to build a human load only machine, where the only method of releasing the ball they have is a truss or goal shot - at that point, does them shooting the ball (where ever) turn an accident into a strategic advantage? Teams with intakes or other methods of doing a 'slow' and or 'controlled' ball release wouldn't really be an issue here, since they could essentially drop the ball where it was caught and carry on with the match.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
