Go to Post In the end, we were successful, but the tale is one of such stupidity that it should be engraved in drool upon a failed math test. - AmLameBro [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 01-17-2014, 07:41 PM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Quick Exhaust Valves - Illegal !?!?
I am extremely disappointed and frustrated by this Q/A ruling: https://frc-qa.usfirst.org/Question/...-per-rule-77-f
I'd argue that quick-exhaust valves are flow control valves under R77-H, because what they do as a function is control flow. They divert the flow of air from one port to another. They are a commercially produced, readily available, pressure-rated component. Okay, maybe it isn't what FIRST means by flow control (with the little knob to slow down the flow of air) but still, what's the harm?
What's the reasoning for ruling them illegal? Making quick-exhaust valves illegal completely invalidates SO many innovative designs, and limits students' exploration of the physics concepts behind pneumatic systems.
What's the history on the legality of these in years past?
Really hoping they reverse this ruling. Until then, we are out hundreds of dollars, and now redesigning our launcher....
Unread 01-17-2014, 08:24 PM
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: Quick Exhaust Valves - Illegal !?!?
That's interesting... For a while, we were thinking of using them too. They are (what I would consider) a flow control valve.
We've put these on our robots for years. I may be remembering wrong, but I think something like that may have been given in the kit in years past.
What's stopping you from getting a solenoid valve with a really high flow rate, then connecting it directly to the cylinder? Also, you'll only need this valve on the retract side, so you could go with a spring/gravity return.
Unread 01-17-2014, 09:18 PM
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
If you have used those valve anytime since 2008 (the year I started FIRST) you were not legal. I use pneumatics in my job, and quick exhaust valve (also called quick-dump) are extremely useful, but have never been FIRST legal. Believe me, there were many years that I wanted to use them!
They are not flow control valves. A flow control valve can restrict the flow, not re-direct it.
Former Mentor Team 1771
Former mentor Team 4509
Unread 01-18-2014, 03:32 PM
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by sanddrag View Post
I am extremely disappointed and frustrated by this Q/A ruling: https://frc-qa.usfirst.org/Question/...-per-rule-77-f...
I've been disappointed too. There have been several prototypes that would have worked if the exhaust wasn't restricted through the solenoid. I guess they want to "err on the side of caution" and ensure there is some dampening of the cylinder.
If y'all haven't seen team 2073 cocking mechanism, take a look: Very clever catapult
Unread 01-18-2014, 03:44 PM
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
just dont hook a fitting up to it. let it be at atmospheric. find another way to retract it
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 01-18-2014, 09:36 PM
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I think there is a fitting that vents and prevents contamination at the same time. I wouldn't leave a cylinder's retraction port open to the particle-filled FRC world.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 01-18-2014, 10:16 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Has anyone run that by Q&A? Ya never know...
Unread 01-18-2014, 10:39 PM
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Since our prototype is currently using a fitting-less downstroke, I went ahead and asked.
Unread 01-18-2014, 10:42 PM
Team Role: Teacher
I'm wondering if there exists such a thing as a "quick exhaust fitting" If so, it would be a fitting, not a valve, and thus rendered legal for use. Anyone an expert of pneumatics manufacturer's catalogs?
Unread 01-18-2014, 11:39 PM
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
Rookie Year: 2011
jmartin is on a distinguished road
Such a thing seems to exist, for example Clippard's JEV-F2M2 (See http://www.clippard.com/downloads/PD...Page%20162.pdf). However, I would expect that even though in they are fittings in one sense, that they might not be legal - especially since Clippard even calls them "valves". And I think (but I'm not sure since I can't seem to find that exact part number) that the quick exhaust valve provided as an example in the question that's already been asked was a fitting type quick exhaust valve too.
Unread 01-19-2014, 09:07 AM
DavisDad's Avatar
MechE
Rookie Year: 2012
Good point Ether! I'm working on the following Q&A's for pneumatics:
  1. Can a regulator be driven by servo to make a proportional control valve (I/P)?
  2. Can one of the two(2) pneumatic cylinder's ports be left open; vented to atmosphere?
Unread 01-19-2014, 09:34 AM
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I'm curious to hear the answer as we have used a 90 degree fitting with no tubing to vent to atmosphere while using gravity to return the cylinder for the last two years. We used it on our ball pickup in 2012 and our climbing arms and disc dump in 2013. Both years we passed inspection at two districts and MSC.
Also, if you put the opening in the cylinder out of the way of a place where dirt and dust can accumulate, there is very little risk of pickup up any debris.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 01-19-2014, 11:50 AM
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
no team (MetalWorks)
Wren Hensgen will become famous soon enoughWren Hensgen will become famous soon enough
Another solution is dual solenoids, each one with one capped port, and one side connected to the cylinder. This lets you push it back down, and then vent to atmosphere.
Unread 01-19-2014, 03:01 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Legal servos don't have the torque needed to turn a pressure regulator.
  #15   Spotlight this post!
Unread 01-19-2014, 03:46 PM
DavisDad's Avatar
MechE
Rookie Year: 2012
Never say never. A geared down continuous rotation servo would probably do it. But but not sure if you'd have needed position control w/out adding POT.
