Go to Post Success in this game comes from a wealth of ideas and good engineering, not deep pockets. - Karthik [more]
Unread 17-01-2014, 20:11
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
Team Role: Leadership
Rookie Year: 2014
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Question Need Help With Robot Jumpyness
Hey guys!
(First post on CD, yay! )
I need some help making our robot less sensitive to the joystick, or some relative acceleration. I am using the basic tutorial code and an arcade drive.
Code:
RobotDrive chassis = new RobotDrive(1,2);
    Joystick main = new Joystick(1);
Code:
public void operatorControl() {
        chassis.setSafetyEnabled(true);
        while(isOperatorControl() && isEnabled()) {
          chassis.arcadeDrive(main);
          Timer.delay(0.01);
Unread 17-01-2014, 20:49
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
Re: Need Help With Robot Jumpyness
Originally Posted by weaversam8 View Post
Hey guys!
Code:
Code:
        double y = main.getY();
        //scale down the max y
        y = y * .6;
        double x = main.getX();
        //scale down the max x
        x = x * .6;
        //dynamically scale x
        if(x > 0){
            x = 1.0057*x*x - 0.0537*x + 0.0237;
        }else if (y < 0){
            x = -1.0057*x*x - 0.0537*x - 0.0237;
        //dynamically scale y
        if(y > 0){
            y = 1.0057*y*y - 0.0537*y + 0.0237;
        }else if (y < 0){
            y = -1.0057*y*y - 0.0537*y - 0.0237;
        chassis.arcadeDrive(y,x);
          Timer.delay(0.01);
I've updated your code with a simple scalar function.
I just used excel and plotted a 2 order polynomial trendline.
Here are the scalars I used:
for less than 0:
in : out
-1 -1
-0.75 -0.5
-0.5 -0.25
-0.25 -0.12
0 0
for greater than 0:
in : out
0.25 0.12
0.5 0.25
0.75 0.5
1 1
If its still too fast I would start by reducing the starting scalar.
"Never let your schooling interfere with your education" -Mark Twain
Unread 18-01-2014, 12:28
Team Captain
AKA: Sam Weaver
Rookie Year: 2014
Thanks, that worked! A note to anyone else who wants to use this, 0.6 is too low of a scale factor for the 2 motor long AM14u chassis, we use 0.9. Also, there was a small error in the code above, one place where it says Y is supposed to be X. I am sure you can see that easily. Thanks again everyone.
