Pneumatics Coding
Hi. I'm the new lead programmer on our team and we want to use pneumatics on our bot. We've never done pneumatics before, so I don't know how to code it AT ALL! If anyone could give me any resources on how to code the Pneumatics or even some sample code it would be much appreciated!
Re: Pneumatics Coding
Here's some code to run a spike relay to control your compressor, and it uses a pressure sensor to turn it off.
Code:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package edu.wpi.first.wpilibj.templates.commands;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.RobotBase;
import edu.wpi.first.wpilibj.templates.RobotTemplate;
public class ManualRunSpikes extends CommandBase {
Relay ms1 = compressor.compressorOne();
boolean thatBoolean = false;
boolean isFlipped;
public ManualRunSpikes() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(compressor);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
if (oi.getB() == false) {
isFlipped = false;
if (oi.getB() == true & isFlipped == false) {
thatBoolean = !thatBoolean;
isFlipped = true;
if (compressor.getCompressorSwitch() == false & thatBoolean == true) {
ms1.set(Relay.Value.kForward);
if (compressor.getCompressorSwitch() == false & thatBoolean == false) {
ms1.set(Relay.Value.kOff);
if (compressor.getCompressorSwitch() == true) {
SmartDashboard.putBoolean("asdf", thatBoolean);
SmartDashboard.putBoolean("switch", compressor.getCompressorSwitch());
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
Code:
package edu.wpi.first.wpilibj.templates.subsystems;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.templates.commands.ManualRunSpikes;
import edu.wpi.first.wpilibj.templates.commands.RunSpikes;
public class Compressor extends Subsystem {
// Put methods for controlling this subsystem
// here. Call these from Commands.
Relay s1 = new Relay(1);
DigitalInput comSwitch = new DigitalInput(1);
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new RunSpikes());
setDefaultCommand(new ManualRunSpikes());
public Relay compressorOne() {
return s1;
public boolean getCompressorSwitch() {
return comSwitch.get();
Code:
* To change this license header, choose License Headers in Project Properties.
* To change this template file, choose Tools | Templates
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.templates.RobotMap;
public class Intake extends Subsystem {
Solenoid shoe = new Solenoid(1, RobotMap.sole); // creates Solenoid
Solenoid spirit = new Solenoid(1, RobotMap.soul); // creates Solenoid
//setDefaultCommand(new MySpecialCommand());
public void push () {
shoe.set(true);
spirit.set(false);
public void pull () {
shoe.set(false);
spirit.set(true);
While you certainly can go with a fully manual method like Bennett has suggested, WPILib will take care of most of that for you. This is all that you really need to do for the compressor.
Code:
Compressor compressor = new Compressor(1, 2); // 1, 2 are locations of your limit switch and compressor relay, respectively compressor.start(); I recommend putting this in your main Robot class, where the compressor is declared as a class variable and you initialize and start in your robotInit() method. You can also create a pneumatics subsystem, and have its default command run the compressor.start() method in the initialize() method. For operating solenoids, the WPILib documentation has an example, you can find that here: http://wpilib.screenstepslive.com/s/...ders-solenoids. If you have any more questions, feel free to ask. |
