Go to Post Let me tell you, the scariest day ever was the day that I realized since I am a mentor, people actually take my advice and I should be careful of what kind of advice I give. :ahh: - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 19-01-2014, 22:27
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: What you've learned about your Makerbot Replicator2
Originally Posted by safiq10 View Post
has anyone have had any expirence in using non-Makerbot filament?
I got a spool of filament from Inventables using the $25.00 PDV and it works just like the Makerbot stuff. Our team's color is bright pink and Makerbot doesn't have it in PLA.
Will definitely buy more filament from Inventables...it's a few dollars cheaper and they have tons of colors.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
  #17   Spotlight this post!
Unread 20-01-2014, 00:18
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
enguneers could you post some links to them ?
  #18   Spotlight this post!
Unread 20-01-2014, 00:27
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
This is off topic, but not worth making a new thread about.
Has any team tried 3D printing a 3D printer? . That'd be cool
I think the replicator has the precision required for such a complex print!
  #19   Spotlight this post!
Unread 20-01-2014, 00:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
330 has, with some success. Go take a look at the RepRap project--the basic premise there is that if you have one, you can build one more with that one, some items from the local hardware store, and a few electronics items.
At last count, 330 had printed something like 3-4 printers worth of parts. I would know: I spent part of a summer keeping an eye on the first two we had while they printed the rest.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #20   Spotlight this post!
Unread 20-01-2014, 17:12
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
Rookie Year: 2000
kprzewodek is on a distinguished road
Originally Posted by engunneer View Post
I've had a makerbot cupcake for a little over 3 years now, and have printed quite a few parts for home and FRC use.
As stated above, closing the chamber helps significantly, especially as seasons change. If your printer is near a window or in a small office, the thermal gradients are pretty bad. I have a single sheet of paper taped over openings to keep the platform and extruder heat in. Especially in ABS, this reduces warping
I haven't used rafts in a long time, but support material is still useful on particularly hard prints. The type of support material and ease of removal depends highly on your model slicer.
For slicers, I ran Skeinforge in RepG for a long time, but now I use slic3r. I've been meaning to try Cura. Both are capable of replicator and sailfish compatible gcode. The main things I like about slic3r are:
  • Place and arrange multiple parts on the print bed
  • way faster slicing than Skeinforge, even on my laptop from 2006
  • separate profiles for slicing, filament, and printers
I have a profile for "Strong" which is 4 perimeters, and 40% infill (agree that going above 40% is rarely useful), "Normal" (3 perimeters, 20% infill) and "Fast" (2 perimeters, 10% infill).
Inputting your filament diameter is critical, and also your extruder steps per mm. without these you will get too much or too little plastic, which can be fatal on the field. You should be able to print a 100% solid cube and have it come out full and flat.
My latest upgrade has been a Raspberry Pi to run my printer - see my blog post on this topic. I have since gotten the wifi configured and have a wireless printer. When I bring it to the school, I switch back to a wired connection.
For print setup, I use:
ABS: 220C extruder, 120C bed, lightly snaded Kapton tape (I have a 4" wide roll) with a layer of Aqua Net (hair spray) for difficult parts.
PLA: 180C extruder, 60C bed, Blue painters tape (3" roll, as above) again with Aqua Net for smaller parts.
If a part is being hard to remove, especially ABS, I just let the bed cool to room temperature, and it pops right off.
ABS parts that need more strength can be put in a warm acetone vapor bath for between 1-60 minutes depending on how much smoothing you want. This glues all the layers together. Let me know if you want to try this, and need more info.
I've had nothing but trouble with ABS adhering to the Kapton tape. Maybe the key is to sand it but I ended up using painters tape, as with PLA, and it has worked so far. I did notice that the older style painters tape seems to work better. The new improved version seems to have a coating or texture that doesn't provide as much grip and my parts pick up.
Also, I would be interested in exploring what you say about acetone vapor bath. That's an interesting way to uniformly bond layers.
  #21   Spotlight this post!
Unread 22-01-2014, 13:20
Peregrine Peregrine is offline
FRC #3324
Peregrine will become famous soon enough
Our team, 3324 has been working with the replicator 2x for a little over a year now. It has become a major part of our workflow moving from CAD design to aluminum manufactured parts. We're even using our machine to create custom wheel spacers some other actual robot parts.
We almost exclusively print in ABS for the strength upgrade. Early on we had some issues with warping but we've mostly solved it all with a combination of frequent and precise plate leveling, increasing bed temperature slightly and applying an acetone/ABS slush mixture onto the plate before each print.
We've started sourcing our ABS from IC3D - it's a local (to us) company creating high quality filament for cheaper than I can find anywhere.
http://www.amazon.com/IC3D-1-75mm-Pr...&keywords=ic3d
http://www.ic3dprinters.com/
  #22   Spotlight this post!
Unread 23-01-2014, 14:11
kprzewodek's Avatar
Rookie Year: 2000
I've heard of this slurry technique but have yet to try it.
Other than a few issues keeping a part bonded to the surface (or slight warp up) I have had much more success printing in ABS than PLA...and it's so much easier to remove support structures. I'm glad I spent the extra money for the 2x because it's so nice to have the option of printing with either.
Here's another source for filament http://www.hobbypartz.com/3dprfi.html. Haven't ordered from them yet but the price seems right. I will try this the next time around. I've heard many stories that the cheaper stuff tends to vary in thickness which causes extrusion issues. Buyer beware as you try new sources.
  #23   Spotlight this post!
Unread 23-01-2014, 15:42
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
We recently bought an aluminum build plate (due to warping of the acrylic one), and have been very satisfied. We got ours from this guy on ebay, and it has been working marvelously. It's significantly heavier, but is also, as advertised, super flat.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #24   Spotlight this post!
Unread 23-01-2014, 17:12
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
DonorsChoose.org just opened up the MakerBot deal in California. And we got one (I think). Can't wait to use all this advice.
