Go to Post Mentors may not be the direct focus of FIRST, but they are just as involved as students are. They play a pivotal role in the success of FIRST and of the success of every team. - Dan Petrovic [more]
Unread 20-01-2014, 13:02
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Vision target location
So, you have the height above the carpet.
The vertical reflectors begin 3 ft. 1 ½ in. above the
FIELD carpet.
You have it's dimensions.
a 4 in. wide, 2 ft. 8 in. tall stripe of retro-reflective material
bordered by 2 in. wide black gaffers tape on the left and right sides
You have it's location relative to another field element.
half is behind the polycarbonate sheet above the LOW GOAL and
half is behind the acrylic panel of the PLAYER STATION
and the low goal, per the drawings is 36.75 inch wide.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-01-2014, 16:01
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Originally Posted by Bruceb View Post
...You have it's location relative to another field element.
half is behind the acrylic panel of the PLAYER STATION...
That's great and all... but there's nothing available to teams which defines the size of the poly sheet or acrylic panel, or their position relative to anything else on the field.
Try to come up with an actual numeric value. If you find an answer, please share. The closest thing to actually define this information is the field tour video linked previously, but it's not clear exactly what they mean by what they say. (as I mentioned in my previous post)
...and the low goal, per the drawings is 36.75 inch wide.
For the record, the low goal is 36" wide. It's 36.75" tall. See page 4 of the low goal drawing. Unfortunately the cube faces aren't labeled.
Originally Posted by Pretzel View Post
To double check it though you could see what the measurement is from the edge of the alliance station to the start of the acrylic since it states that it is mounted such that half of it is on the polycarb above the low goal and half of it is on the acrylic in front of the drivers.
This dimension isn't available in any materials provided to teams by FIRST. If you have come a cross it, please share.
http://team2168.org
Last edited by otherguy : 20-01-2014 at 21:28. Reason: added note about goal width/height
Unread 20-01-2014, 16:28
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2012
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Figure 2-9 shows it being the same width as the low goal, and the polycarbonate is specifically referred to as being above the low goal. This would lead me to believe that it is the same width as the low goal, or 2 ft 8 1/2 in + the width of the material that makes up the low goal. I could be wrong on my interpretation, but I believe this to be correct.
It's not done until it's overdone!
Unread 20-01-2014, 21:21
otherguy's Avatar
sparkE
AKA: James
There are no dimensions on Figure 2-9, nor are the acrylic/polycarb sheets identified. Its just a picture of the wall. There's no guarantee it's dimensionally accurate. You had to make the assumption that the poly sheet is the same width as the low goal, but there's nothing in the picture or the text that states that as fact.
I have also come up with a number, which I believe to be correct, based on how I've interpreted the information provided by FIRST (I followed a different path than you've outlined). It's not a matter of just getting an answer though, I want the right answer. Which is why the questions were posted to the Q&A.
http://team2168.org
Unread 20-01-2014, 22:24
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
Rookie Year: 2014
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
The video shows a gap between the right edge of the left-lower goal, and the center line of the reflective strip. There is no indication anywhere as to what that distance is.
Unread 21-01-2014, 16:48
otherguy's Avatar
sparkE
AKA: James
Got an answer, see team update 2014-01-21.
Specifically page 4 of FE-00037_RevA.pdf
http://team2168.org
Unread 20-01-2014, 10:15
otherguy's Avatar
sparkE
AKA: James
I posted two questions to the q&a last week: q157 and q158.
Sorry for the excessive use of abbreviations, was struggling to stay within character limits.
I agree that there isn't enough information in the manual, any of the drawings, or the video to relate the targets to one another. Particularly in the horizontal dimension.
The video defines the vertical targets position relative to the "inside edge" of the low goal. Does that mean the face of the cube furthest from the field perimeter, or does it mean the edge of the opening in the cube through which you could score a ball. I interpreted the later, but others on my team disagree.
Also, are the measurements provided relative to the vision target's reflective material, or the black border which surrounds it? The game manual makes it sound like the black border is considered part of the target, so my hunch is the later, but this isn't an element of the field I want to approximate. I want it to be as accurately replicated as possible. This should be a relatively easy set of information for FIRST to provide, the game manual has all but one dimension defined already.
http://team2168.org
