Go to Post It's very confusing to other people on the message boards when you make things up that are incorrect and assert them as fact. Please don't do this. - Dave Flowerday [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 18-01-2014, 14:16
MechaKnight996 MechaKnight996 is offline
FRC #0996
MechaKnight996 is an unknown quantity at this point
Exclamation Tank Drive
Hi, I'm not the best programmer and i need some help. If anyone could post an example or a link to an example of a working tank drive teleop program for FRC 2014. Thanks.
Unread 18-01-2014, 14:26
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Tank Drive
A working example comes with your FRC software development installation.
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
Rookie Year: 2013
samfruth will become famous soon enough
Re: Tank Drive
Here is a screenshot of our current tank drive system, I hope it helps!
Unread 18-01-2014, 21:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Tank Drive
On the left side of LabVIEW's Getting Started window, you will see a "Support" tab. When you click it, one of the links is "Find FRC Examples..." which will open the NI Example Finder and show the FRC Robotics section.
On the "Tutorials" tab, you will want to read "Tutorial 7 - Integrating Examples into Robot Code".
Unread 18-01-2014, 22:11
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Tank Drive
Here's yet another Tank drive example:
Unread 18-01-2014, 23:23
Software Architect
Re: Tank Drive
Notice that the only things making it Tank drive instead of the default Arcade drive are the use of the "Tank Drive" function and a second joystick. That second joystick will have to be opened in Begin, just like the first one, and they will both have to be given appropriate RefNum names.
Unread 20-01-2014, 12:47
FRC #0996
Re: Tank Drive
Thank you for all your help.
