Go to Post it was beautifull just beautifull... then i took my earmuffs off. - Tytus Gerrish [more]
Unread 18-01-2014, 15:48
inform880 inform880 is offline
FRC #2137
inform880 is an unknown quantity at this point
Question Halo Drive
Hi,
I want to create a Halo Drive for our six wheel robot with 4 jag motor controllers. The idea is that one stick would be for the speed and the other would turn the bot.
I honestly don't know where to even start. I don't know what sort of algorithm to use or what function would be aproprate.
What algorithm should I use? What function should I use?
Thanks,
inform880
Unread 18-01-2014, 16:14
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Halo Drive
WPILib:
Code:
 * Drive the motors at "speed" and "curve".
 * The speed and curve are -1.0 to +1.0 values where 0.0 represents stopped and
 * not turning. The algorithm for adding in the direction attempts to provide a constant
 * turn radius for differing speeds.
 * This function will most likely be used in an autonomous routine.
 * @param outputMagnitude The forward component of the output magnitude to send to the motors.
 * @param curve The rate of turn, constant for different forward speeds.
void RobotDrive::Drive(float outputMagnitude, float curve)
Unread 18-01-2014, 22:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Halo Drive
If your six-wheel drive has normal traction wheels, with three driven together on one side and three driven together on the other side, it doesn't have the ability to move sideways. I would usually reserve the term "Halo drive" for a robot that can travel in any direction without first having to rotate to face that direction.
It sounds like what you're looking for is a typical Arcade drive, but with the speed and spin on separate joysticks. The usual Arcade drive uses the Y axis of a joystick for the speed, and the X axis of the same joystick for the spin. For your application, simply use the X axis of the other stick instead.
