Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
Unread 18-01-2014, 16:17
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
SmartDashboard 2.0 not connecting until driver station is run
Has anyone had trouble with Smartdashboard 2.0 not connecting to the robot until the driver station is running? We've tried multiple computers, and it doesn't seem to connect until the driver station runs. It doesn't even seem like it matters what the driver station is set up for. I was trying to connect to one robot, and opened the driver station configured for a different team number and as soon as the DS opened, Smartdashboard connected to the robot.
Unread 19-01-2014, 10:57
Re: SmartDashboard 2.0 not connecting until driver station is run
I haven't used SD 2.0, but the DS does send packets to the dashboard. It could be that the dashboard is blocked waiting for those packets. Those packets do include robot info like IP address, but they may not be used by SD.
Greg McKaskle
Unread 19-01-2014, 14:53
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
No, SFX does not wait for DS status. My guess is you are not adding information until enable/etc the robot. What happens if you put the add information in the constructor?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 19-01-2014, 16:12
Rookie Year: 1997
We did have SD stuff in the constructor. I'm using last year's robot code, which has a lot of SD stuff.
I've been playing with it some more today, and it isn't related to the DS or SFX. Sometimes it takes a very long time to connect (which may have been coincidental that it started when the DS opened). I've also seen cases where the old SD doesn't connect (or takes a very long time to connect). I'll keep playing with it to see if if it's something in our code, or something in the NT code.
