Go to Post ps... it is better to have built a robot and lost than to ever played basketball at all - Andy Baker [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #16   Spotlight this post!
Unread 19-01-2014, 00:58
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: TEAM 1448 Build Progress
Originally Posted by Bwalker View Post
Thats definitely pretty ingenious. From your drawing your plunger is powered by a motor quickly spinning the plunger out if I've looked at it correctly?
Thank you
I should have been more clear with the second rendering. There are two carriges that run on the 80/20 beams. The front one is connected to a PVC plunger and is held to the front of the track with surgical tubing. The second carriage is connected to the lead screw. The second carriage is powered forward after each shot, where it latches on to the first carriage using a pair of pistons and then draws the whole thing back. Its like cocking a crossbow. When we want to shoot the latches release and let the plunger (and first carriage) fly forward and punch the ball into the air.
What is not shown in the rendering is the surgical tubing, the plates that attach the plunger to the first carriage, and the plates that attach the lead screw to the second carriage.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
