Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 18-01-2014, 22:41
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
2014 Vision Code
Hello there everyone!
Our team is trying to work with the camera to track those vision targets to calculate distance and whether or not the goal is "hot" in autonomous.
Can anyone help us out? This is our first year using vision, and we're lost.
We've tried copy/pasting the example code, but it brings up errors about lost VIs and such. We tried using the vision assistant, but as I'm sure you know, it's pretty daunting and looks pretty complicated.
I've looked at MANY tutorials, but couldn't find one that helps us in general.
Any help would be greatly appreciated :-D
Unread 18-01-2014, 23:27
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 2014 Vision Code
Did you look at "Tutorial 8 - Integrating Vision into Robot Code"?
Unread 19-01-2014, 10:57
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Wow! Why didn't we see those? Thanks! We'll look through that!
Thanks!
Unread 19-01-2014, 17:07
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
This section of the FIRST/WPI documentation also covers some of the theory behind the example, including topics like calibration: http://wpilib.screenstepslive.com/s/3120/m/8731
Unread 19-01-2014, 17:34
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
We looked through that, but like you said. Those are the theories, not the step-by-step guide we want/need for being our first time working with vision.
Thanks for the link though :-)
Unread 19-01-2014, 23:56
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
How are you planning on doing vision: through cRIO, send it to driver station, or use an on board computer?
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 20-01-2014, 09:51
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Team Role: Leadership
Rookie Year: 2010
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
I would highly suggest either doing the processing on the driver station or a coprocessor. Our team has already run into issues with letting the crio do the thinking...
Per Audacia Ad Astra
Unread 20-01-2014, 11:03
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Sounds like we're going to do it on the Driver Station. My next question is (after going through the steps in the tutorial), how do we get that data (variables) to talk with the cRIO code?
Unread 20-01-2014, 11:36
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Looking at it more...I think processing on the cRIO would be easier. We're only using Vision for Autonomous, then we're planning on disabling vision.
Unread 20-01-2014, 14:27
Whichever way you decide to go, it is helpful to share data between DS and robot. The tutorial touches on this, and I've participated in a few other CD threads that go deeper. If those don't answer your questions, please ask.
Greg McKaskle
Unread 20-01-2014, 15:12
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Careful with that. When we tried that in the past, we found that it lagged the cRIO so much that we started getting watchdog errors - the cRIO couldn't communicate fast enough.
As for sending data from the DS back to the robot, you can usually just use NetworkTables to send the data. NI's code and RoboRealm both have easy NetworkTables integration built-in. (Not sure about OpenCV, haven't tried it.)
Unread 20-01-2014, 15:32
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Thank you all for the help! We'll be doing some major testing to find the best route to go with and I'll come back with some questions if needed.
Thanks again!
Unread 21-01-2014, 21:36
That all depends on the rate and complexity of the processing. You could probably get away with processing 1 image per match this year which shouldn't cause any problems at all running on the cRIO.
Unread 23-01-2014, 09:53
bvisness's Avatar
Rookie Year: 2010
Depending on your auton routine of choice, I suppose. We're going to try for more complex autonomous routine this year, so we'll need as much flexibility in the vision as we can get.
  #15   Spotlight this post!
Unread 23-01-2014, 10:57
The LV example code for finding a game ball is takes two passes. While it would run on the cRIO, the robot and potentially the ball are both moving. I would think it would be hard to accomplish this without a DS or additional processor. The field targets seem pretty easy to do on the cRIO or any of the other approaches. By the way, "easy-vision" is still vision -- it's all relative.
Greg McKaskle
