IMAQ Deployment Error
My team and I are experiencing a very weird issue.
Whenever we copy and paste the 2014 Target Detection VI to our Vision Processing VI and deploy the code onto our robot, we get the following error: Deploying IMAQ AVI2 OpenIMAQ AVI2 Open loaded with errors on the target and was closed. LabVIEW (Hex ox627) The function name for the nivissvc.*: LV_AviMovieOpen2:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name. Deployment completed with errors We have tried many things to fix the code, and nothing worked. All help will be appreciated.Last edited by Joseph DeRoest : 18-01-2014 at 23:10. |
Re: IMAQ Deployment Error
I believe that you have copied and pasted the code on the left that reads images from disk. Or through some other edit you have added a dependency to AVIs. Those are a Windows specific feature and will not work on the cRIO.
If you post an image of the code, it may be visible. You can also find ctl-F and look for movie or avi and see which function is trying to operate on AVIs. Greg McKaskle |
