Go to Post if your robot weighs 1-1/2 tons, you have bigger problems then the legality of that jack... - ekapalka [more]
Unread 19-01-2014, 06:02
idoshamir idoshamir is offline
FRC #5038
idoshamir is an unknown quantity at this point
Planetary Gearbox with RS775 Motors from AndyMark?
Can someone affirm that the following sets from AndyMark are legal in FRC 2014? Sorry this is probably obvious but we are a rookie team and we want to make sure.
• PG71 Planetary Gearbox with RS775 Motor (am-0914)
• PG188 Planetary Gearbox with RS775 Motor (am-2193)
Thank you!
Unread 19-01-2014, 07:38
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Planetary Gearbox with RS775 Motors from AndyMark?
Thank you!
The rules apply only to the motor, the gearbox doesn't matter. R29 lists all legal motors, which includes the am-2161 motor. This is the RS775 motor included in the PG71 and PG188.
Unread 19-01-2014, 07:40
FRC #5038
Thanks!
