Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 19-01-2014, 08:09
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Pneumatic Proportional Control Valve
Our team is prototyping a pneumatically driven catapult shooter. We're copying the design generously shared by team 2073 (see this thread: 2073 Pneumatic Catapult
We'd like to control the cylinder supply pressure with a proportional control valve (aka I/P). Has anyone done this.
In the past, I've modified a regulator by changing the diaphragm spring and replacing screw with driver rod: illegal for FRC. Here's an idea of how to adjust a regulator via a servo without directly modifying the regulator (see pic below). Would this be allowed?
Unread 19-01-2014, 09:13
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: Pneumatic Proportional Control Valve
I've seen a team do this in the past. I have no clue if it was legal then, or if it legal now. However, I'm concerned that a servo doesn't have enough torque to turn the knob on the regulator. The team that did this in the past used one of the mabuchi motors (wow, that was a long time ago) with a huge pulley reduction.
Unread 19-01-2014, 09:18
DavisDad's Avatar
MechE
Rookie Year: 2012
Roger that on the torque power. Will probably require a gear-motor. Just wanted to show in a quick sketch...
Thanks for the reply; much appreciated!
Unread 19-01-2014, 09:51
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Rookie Year: 2010
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Aside from needing a more powerfully adjuster as the primary 60 psi I would call it as a real no-no since you have no way to prove the maximum 60 psi working pressure is controlled by sensor feed back.
If this was another regulator AFTER the main 60 psi regulator then go for it.
Unread 19-01-2014, 09:59
DavisDad's Avatar
MechE
Rookie Year: 2012
Right- pneumatics would be downstream of regulation set-up:
Compressor --> Safety Relief (125 psi) --> Pressure Switch (124 psi) --> Reservoir tank(s) --> Regulator (60 psi) --> Solenoid --> Prop. Control Assembly --> Accumulator --> Cylinder
Thanks for the input.
Unread 19-01-2014, 10:04
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I wanted to do this some for some time. There are other regulators that have a t handle and do not require as much force at the almost full pressure setting. One I looked at was 10 turns for the whole range. Almost could use a 10 turn pot for positioning. Never went further. There are commercial electronic regulators that would do this. Price is the biggest problem.
Unread 19-01-2014, 10:50
DavisDad's Avatar
MechE
Rookie Year: 2012
Originally Posted by Gdeaver View Post
...There are commercial electronic regulators that would do this. Price is the biggest problem.
HVAC control valve "I/Ps" aka "V/Ps" are cheap on eBay but probably not legal: link -->
It may be possible to create a feedback control loop by adding a pressure transducer and pulsing the legal solenoid.
