Go to Post I...want...to...go...to...Champs. REALLY REALLY BADLY. - CalTran [more]
Unread 19-01-2014, 09:24
kevster9876 kevster9876 is offline
FRC #2079
kevster9876 is an unknown quantity at this point
Need help on downloading labview
What hard drive is the popup asking for?
Kevin
Unread 19-01-2014, 10:19
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Team Role: Leadership
Rookie Year: 2010
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Need help on downloading labview
Are you trying to install the FRC updates before installing this year's LabVIEW 2013? Or trying to install FRC updates on top of last year's LabVIEW?
Per Audacia Ad Astra
Unread 19-01-2014, 15:44
FRC #2079
I havv already downloaded the 2013 Labview. The image is the Frc 2014 Update Suite
Unread 19-01-2014, 19:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
From where did you download LabVIEW 2013? Is there a reason you didn't use the copy that came in the Kit of Parts?
Unread 19-01-2014, 22:45
FRC #2079
No I used the DVD in the kit of parts. The other download was to make the original Labview change to the FRC version. That could only be found at the national instruments website.
Unread 20-01-2014, 01:21
Software Architect
I think that it's asking for device drivers for any NI hardware you have installed in your computer. You probably don't have any, so you probably want to "Decline" support.
Unread 20-01-2014, 08:14
FRC #2079
But if I decline, then the download fails and I can't get the
FRC version of Labview.
Unread 20-01-2014, 23:06
Software Architect
Did you unzip the update into a folder before running the setup.exe program, or did you just run setup.exe from inside the compressed archive? Trying to install from inside a .zip file rarely works.
Unread 22-01-2014, 11:52
FRC #2079
What if I downloaded a NI device driver and then tried to run the set up again?
Unread 22-01-2014, 11:58
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You may have better luck getting support for installation problems directly from NI. http://www.ni.com/frc
