| View Poll Results: What's your drive base? | |||
| 6/8 Wheel Tank |
169 | 71.31% |
| Mecanum |
33 | 13.92% |
| Swerve |
7 | 2.95% |
| Omni Drive |
6 | 2.53% |
| Octocanum |
8 | 3.38% |
| Other? |
14 | 5.91% |
| Voters: 237. You may not vote on this poll | |||
Re: How are you Driving?
6WD with 4" VexPro DT wheels, belts, and a single speed gearbox. We tried to keep our drive train as simple and robust as possible while still giving students working on the drive train a good amount of experience designing custom parts.
Unfortunately, our plans to get drive bases up as quickly as possible have fallen a little bit out of whack due to VexPro delays and some problems with machining. Luckily we're still about twice as far as we were at this point last year. |
Our very early prototype |
If we have the weight, we're likely going to add four mini-CIMs to the drivetrain--but we have to hold off on that until we're sure we can swing it. |
That is why I noted it is very early, we redid the pistons (longer stoke and larger bore) before last season so now it is tight in both position, however we found last season that 25 chain would stretch to much so we switched to 35 chain. We have not had an issue with it since.
We're using 8 4" VexPro traction wheels. We're also making a plate-aluminum chassis for the first time in my team's history, as well as switching from our custom Thunder Drive transmissions to West Coast Product's 2 CIM Dog Shifter.
I'm excited we're using octocanum again. The new VexPro wheels make packaging everything within the smaller frame perimeter a lot easier.
http://imgur.com/Xel5dWw |
We're doing the KOP frame with a 28" square base and Sonic Shifters with 4 CIMs.
We've never done shifters before and the new KOP chassis makes upgrading easy. Should be interesting... Haha. |
#10
West Coast Best Coast!
#11
#12
In support of this FRC558 is running an 8WD with 4"x2" Colsons and #35 Chain.
#13
3467 will be running 6wd 4in x 1-1/2in Colson wheels and 3 CIM Ball Shifters.
Its time we catch on to the East Coast Conspiracy of Colsons. |
#14
#15
If I can make the quick argument here. West coast drive is extremely light, provides a very large wheel base, keeps the chains or belts protected and properly tensioned. In addition all of the parts to make one are now available OTS and it's been iterated to near perfection by teams like 254 and 973 if you want to find look for examples on how to do implement it most effectively.
