Go to Post (puts on his asbestos underwear, because these threads always get heated) - Billfred [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 19-01-2014, 16:05
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Homing Beacon for Catching Ball
My son had the idea to having a homing beacon a team could lend to alliance partner; something that'd report distance as well as angle. I think sonar sensor/beacons can do this...
Unread 19-01-2014, 17:55
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
Rookie Year: 2007
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Homing Beacon for Catching Ball
Unfortunately that is illegal in the rules.
1. you cannot have any sort of wireless communication to or within the robot.
2. The beacon would have to be build by team whose robot is it on which is not possible.
-Borna Emami
Team 0x27
Unread 19-01-2014, 21:28
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
It depends on how you want to use the beacon. If you are just trying to determine the position of your alliance partner, relative to your own robot, you could construct a system which would be within the rules.
You could mount a camera on your robot, and look for a unique feature that you place on another robot. Think of the florescent targets on the 2009 robots. Or train your camera on a unique fiducial marker that you've trained your camera to detect.
If you're trying to send information to an alliance partner (inter-robot communication), I con'at think of a way to legally implement this that would be reliable enough to use in competition.
http://team2168.org
