Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 01-19-2014, 05:47 PM
blanketboyjo blanketboyjo is offline
FRC #0687
blanketboyjo is an unknown quantity at this point
File IO without overwriting file
Hi, so I am trying to make the CRIO print out to a text file that I can read through ftp. I have it working to make the file, but everytime the code runs it overwrites the file, is there any way to make it so that new lines are added to the existing file?
Code:
PrintStream writer;
DataOutputStream myFile;
FileConnection con;
try {
con = (FileConnection)Connector.open("file:///test.txt", Connector.WRITE);
con.create();
myFile = con.openDataOutputStream();
writer = new PrintStream(myFile);
} catch (Exception e) {
writer.println("Message");
