Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 24-01-2014, 20:55
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: VexPro WCP DS Gearbox Assembly
It doesn't fall apart easily on its own, but its pretty easy to pull off with fingers. just not real confidence inspiring. I don't have access to it till tomorrow.
I noticed it when I was swapping the bearings for the 2 gears, they were switched, round-hex.
  #17   Spotlight this post!
Unread 24-01-2014, 20:59
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
If you can easily pull it with fingers, it'll fall out in no time on a vibrating and shaking FRC robot. If you have the right size bearing, the hole is probably oversized a bit, which is bad for me, because I'm counting on it being a press fit for our winch thing, and if it's not, I don't have time to wait for another gear to get here...
I'm assuming you have the other dog gear for the transmission (and another set for a second gearbox?). When you get access to the gears, could you see if they're all like that?
  #18   Spotlight this post!
Unread 24-01-2014, 21:09
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
The bearings were loctited in with loctite 680, and it was probably applied a day or two ago, If you feel the bearing is not retained enough remove the bearing clean it and apply a fresh coat of this loctite and allow it time to properly dry in not cold temperatures (ala UPS truck).
The bearing does not see any significant side forces.
Things are moving quick around here
Let me know if you have any issues.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
  #19   Spotlight this post!
Unread 24-01-2014, 21:29
BJT's Avatar
BJT BJT is offline
AKA: Ben Thorsgard
Thanks, thats what I needed to know.
