Go to Post There is more to our team than my hair, you know. :P - thefro526 [more]
Unread 20-01-2014, 11:59
Just_In_Time Just_In_Time is offline
Rookie Year: 2010
Just_In_Time is an unknown quantity at this point
[FTC]: 2 vs 4 Tetrix Motor Encoders?
Hello. My team is using motor encoders for the first time this year, and we're unsure about how many we will need. We currently have a 4-motor drive train with each motor separately powering each of the 4 wheels of our drive train. We were wondering if we need to use 4 motor encoders for it to work properly, or is there a way to only use 2 by putting one motor encoder on each side of the drive train? Any help is greatly appreciated. Thanks.
JIT
Unread 20-01-2014, 12:54
FTC4211's Avatar
FTC4211 FTC4211 is offline
AKA: John Stegeman
FTC #4211 (The Bombers)
Rookie Year: 2010
FTC4211 is an unknown quantity at this point
Re: [FTC]: 2 vs 4 Tetrix Motor Encoders?
Your options depend partially on how you have the motors wired into the motor controllers. If you have both motors from one side of the drive going into the same motor port on the motor controller then you have to use only one encoder per side of the robot. If each drive motor has its own motor port then you can use either two or four encoders.
More broadly most teams can use only two encoders and be perfectly fine. When driving in a straight line where wheel slippage is minimal, two encoders work just as well as four encoders. The only spot you may see a difference is during turning. With four encoders you have the option to check for and account for potential wheel slippage, but requires much more software to actually achieve significantly noticeable advantages over only two encoders.
My suggestion would be to start with only two encoders, placed on the wheels with the most traction (tetrix rubber wheel before an omni wheel, or the wheels with the most weight over them) as this will provide the best representation of the overall drive train with only the two encoders. Fewer encoders means less software, and one less thing to fail. If the two encoders are not providing the accuracy that you looking for, then add the other two encoders. Generally the less there is to worry about the more reliable it is.
Team 4211
Unread 20-01-2014, 13:07
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
Rookie Year: 2010
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
One other reason to use 4 is that 4 allows for PID to be enabled in autonomous. I find that that makes autonomous routines much more repeatable.
--Jacob
Illinois FTC FTA
Unread 21-01-2014, 01:12
Rookie Year: 2010
Thank you all very much for your help. 4 seems like it will work better in the end for improved accuracy. Thanks again.
JIT
Unread 21-01-2014, 14:45
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Team Role: Coach
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
We are actually using just 1 encoder (and a gyro and IR sensors) - and it works fine for us, too. Robot motion is accurate to within 1 inch.
Unread 26-01-2014, 03:02
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
It also depends on what kind of wheels you have. If you are using mecanum wheels, you need all 4 encoders to figure out x and y displacements. If your robot can only go forward and backward but not sideways, then 2 are probably just fine. Our robot is 4-wheel swerve drive each with an independent motor and encoder. So our code can keep track of both x and y displacements.
