Go to Post Test your code and your assumptions. - ShotgunNinja [more]
Unread 20-01-2014, 16:19
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
Rookie Year: 2012
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Raspberry Pi
Team 2537 is planning on using a Raspberry Pi on our robot for targeting.
The Raspberry Pi will have an ethernet connection to the radio/bridge on the robot.
Our camera and cRio will also be connected into the radio/bridge.
Is there any rule issues with this configuration?
We are aware of the bandwidth limitations and will account for that.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
Unread 20-01-2014, 16:49
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Raspberry Pi
Your configuration is acceptable and does not break any rules.
The bandwidth limit is only in effect if you are sending data off board from the robot to the driverstation, there is no bandwidth limit on the local network between the robot and the camera from the D-link switch, so unless you plan to stream the images back to the DS, vice just sending strings back, you need not worry about the bandwidth limit.
Also be sure, if you do plan to send data off board to the DS you can only use certain socket ports as defined in the manual.
hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 21-01-2014, 14:07
FRC #2537
Rookie Year: 2012
Re: Raspberry Pi
hope this helps,
Kevin
Thanks! Just trying to make sure our setup is legal.
Unread 21-01-2014, 14:18
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
Rookie Year: 2011
jmartin is on a distinguished road
Re: Raspberry Pi
We (Team 172) had just about the same setup last year, and it worked perfectly (Aside from the fact that our vision processing code wasn't the best). Good luck to you!
