Go to Post Many people here in the CD fora know 'someone' on the inside. They aren't out there somewhere, they are here among us and they won't give an inch regarding the clues. It's very cool. - JaneYoung [more]
Unread 20-01-2014, 16:25
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
Rookie Year: 2011
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
Star Lock Washers for Talons
I would like to use star lock washers, sold at mcmaster here http://www.mcmaster.com/#91114a007/=qc5f1i, with the screw connections on Talons. Has anyone done this before and/or have any serious concerns about doing this? I would just do it, but one particular mentor is afraid they might do something wacky. Thanks for your input.
Unread 20-01-2014, 16:34
m1tche11d m1tche11d is offline
m1tche11d
FRC #1997
Rookie Year: 2010
m1tche11d is an unknown quantity at this point
Re: Star Lock Washers for Talons
What concerns in particular did this mentor have? I would think that as long as the wire is securely crimped to the connector, and the connector is tightly screwed down, it wouldn't matter what kind of washers or nuts you use.
Unread 20-01-2014, 16:40
Rookie Year: 2011
He was concerned that they would add no benefit, like that no washer at all would be just as good as using a star washer. I think that i would create a more firm connection and possibly drop the resistance of the connection.
Unread 20-01-2014, 16:48
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
Rookie Year: 1997
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
It's unlikely to have any substantial impact on resistance. If anything it might slightly (very slightly) increase resistance at the connection. Most of the electrical connection is between the flat surfaces of the terminal and the screw's post. Adding a toothed washer would (technically) increase resistance between the top side of the terminal and the screw head, but even then it would be on the order of milli- or maybe even micro-ohms.
The bigger reason for a toothed washer is to provide a more vibration resistant connection. Those teeth dig in and prevent the screw from rotating if the connection starts to vibrate. Whether that is significant in your mind is up to you. But, I have seen teams do this, particularly on battery terminals.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 20-01-2014, 16:50
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
We have never used a serrated washers on our motor controllers & never had an issue. I have used serrated washers in the plant when I needed a good electrical connection. Pretty standard for grounds in UL listed boxes. So they won't hurt.
Unread 20-01-2014, 16:51
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
If you are worried about losing connection, use ring terminals. Have you had anything come lose? I haven't had anything come lose before and I usually use U terminals. I don't know if they will cause anything bad to happen but I personally don't think you need them.
Unread 20-01-2014, 16:55
FRC #6357
Rookie Year: 1997
Or, split the difference with a locking spade terminal:
http://www.mcmaster.com/#8007k14/
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 20-01-2014, 17:15
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We use these on all our speed controllers and batteries. They work pretty well to not allow the the connections to come loose over time.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 21-01-2014, 06:17
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
In my experience, serrated lock washers on terminal block screws cause more harm than good. Most of these screws are plated brass and the serrations just tear them and the terminals up. A properly torqued terminal block screw will not loosen up over an FRC season.
And always use ring terminals. They are a pain to use sometimes, but a loose connection won't flop around and touch something you'd rather it didn't.
Unread 21-01-2014, 07:27
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Rather than trying to further secure the screw connection on the speed controller, I recommend that all power connections to speed controllers be tied down on either side with a tie wrap connected to a base, DigiKey RP302-ND or equivalent. This greatly reduces vibration at the screw connectors on the speed controller.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 21-01-2014, 09:11
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I believe the controllers come with binding head screws so that lock washers are not really needed. You can use lockwashers if you wish. I recommend lockwashers for use between the wire terminal and battery terminal. This prevents the two from twisting in use, loosening the hardware and causing significant losses.
Al
WB9UVJ
www.wildstang.org
________________________
