Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 20-01-2014, 17:31
jnoyeslaser jnoyeslaser is offline
Coach Noyes
FTC #5905 (Camdenton 4-H LASER)
Team Role: Coach
jnoyeslaser is an unknown quantity at this point
[FTC]: Servo to button programming teleop
I am a first year FTC coach trying to learn the world of RobotC programming after years of FLL coaching. My team is stuck on programming their two arms to pick up blocks. The following code is our attempt. The robot will drive using joysticks but we can't make the second controller move the arm nor can we make the buttons work. I have looked through the post both here and on the robotc forum but find nothing to help me function them the way the kids would like. They want the trigger buttons to open and close their "hand" servo, the 1-4 buttons to move the "shoulder or elbow" servo up and down, and the DC motor "lift" to be moved by the joystick on controller 2. Anything you can give us would be great help as we compete in 2 weeks. Thank you so much
#pragma config(Hubs, S1, HTMotor, HTMotor, HTServo, none)
#pragma config(Sensor, S1, , sensorI2CMuxController)
#pragma config(Motor, mtr_S1_C1_1, motorRight, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C1_2, motorLeft, tmotorTetrix, openLoop, reversed)
#pragma config(Motor, mtr_S1_C2_1, motorLift, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C2_2, motorL, tmotorTetrix, openLoop)
#pragma config(Servo, srvo_S1_C3_1, servoTleft, tServoStandard)
#pragma config(Servo, srvo_S1_C3_2, servoAleft, tServoStandard)
#pragma config(Servo, srvo_S1_C3_3, servoTright, tServoStandard)
#pragma config(Servo, srvo_S1_C3_4, servoAright, tServoStandard)
#pragma config(Servo, srvo_S1_C3_5, servo5, tServoNone)
#pragma config(Servo, srvo_S1_C3_6, servo6, tServoNone)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
#include "JoystickDriver.c"
void initializeRobot()
// Place code here to sinitialize servos to starting positions.
// Sensors are automatically configured and setup by ROBOTC. They may need a brief time to stabilize.
servo [servoAleft] = 250;
servo [servoAright] = 150;
servo [servoTleft] = 100;
servo [servoTright] = 100;
return;
int RarmPos = 0;
task main()
//servoAleft needs to be set//
initializeRobot();
waitForStart(); // wait for start of tele-op phase
while(1 == 1)
getJoystickSettings(joystick);
//deadzone on drive motor on joy1
if(joystick.joy1_y2<5 && joystick.joy1_y2>-5)
motor[motorLeft] = 0;
else
motor[motorLeft]= joystick.joy1_y2/2;
if(joystick.joy1_y1<5 && joystick.joy1_y1>-5)
motor[motorRight] = 0;
else
motor[motorRight] = joystick.joy1_y1/1.5;
//right arm tele two tests have been tried
// if(joy2Btn(5))
//servo[servoAright] = 200; //Open
//if(joy2Btn(7))
//servo[servoAright] = 75; //Closed
if (joy2Btn(6))
RarmPos += 5;
if (RarmPos > 255)
RarmPos = 255;
else if (joy2Btn(8))
RarmPos -= 5;
if (RarmPos < 0)
RarmPos = 0;
servo[servoAright] = RarmPos;
//Lift Motor joystick 2 Y1 (left joystick) This one doesn't seem to function properly
if(joystick.joy2_y1<5 && joystick.joy2_y1>-5)
motor[motorLift] = 0;
else
motor[motorLift]= joystick.joy2_y1/2;
//left arm tele
if (joy1Btn(5))
servo[servoAleft] = 200; //Open
if (joy1Btn(7))
servo[servoAleft] = 75; //Closed
//Top Servo Motors to work the shoulder of the arm using the buttons on the right
if (joy2Btn(1))
servo[servoTleft] = 20; //Closed
if (joy2Btn(3))
servo[servoTleft] = 125; //Open
if (joy2Btn(2))
servo[servoTright] = 20; //Closed
if (joy2Btn(4))
servo[servoTright] = 125; //Open
