Go to Post Thou Shalt Not Leave Crap In The Walking Path. - Billfred [more]
Unread 20-01-2014, 19:10
Ladiesman217 Ladiesman217 is offline
FRC #3965
Ladiesman217 is an unknown quantity at this point
Help with basic LEDs
Hey everyone, our team decided to use LEDs on our robot for the first time this year, but we have no idea how we can power these things legally. We just want something very basic, we turn the robot on, the LEDs turn on. thats it. if you have any recommendations for LEDs (purple specifically) please let me know! Thanks
Unread 20-01-2014, 19:19
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Help with basic LEDs
One very easy way is to use a spike relay. It's on/off, controllable, and reliable. Add some connectors and maybe some extra (legal size) wire to get it to where you need it, and you've got a powered LED that you can control!
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 20-01-2014, 21:40
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Someone correct me if I'm wrong, but the LEDs would be considered a Custom Circuit under R40.
Custom Circuits can connect directly to the PD board, protected by a snap action breaker (up to 40A - likely way more than you need for LEDs) per R46.
Wired in this manner the LEDs could not be turned on/off.
If you wanted to turn them on/off, you're allowed to connect custom circuits to any device listed in Table 4-4. The Spike Relay module would likely be your best bet IMO.
http://team2168.org
Unread 20-01-2014, 23:47
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
FRC #0294 (Beach Cities Robotics)
Rookie Year: 1998
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
First select the source and quantity of Purple LEDs you wish to use.
Individual LEDs come with and without internal current limit (resistors)
Group strings of LEDs are available
Xmas types 110vAC NOT 12.6v DC in robot would need rewired - a pain
Motorcycle 12.6v strings recommended (see below for link)
Each color of LED has a specific Forward Voltage drop
(say 1.1v for red up to ~3.6v for blue/white)
with a specified maximum forward current rating..
Together with the known supply voltage,
the correct current limit resistor may be calculated....
Rvalue = (Vsupply - (#LEDs in series * Vfwd)) / Ifwd in Amps
Rvalue_redLEDexample = 12.6v - (8eaLEDs * 1.1v) / .030 = 127 ohms
so use a 1/4w or greater wattage carbon resistor of approx. 127 ohms
Wwiring up & ruggedizing such a string is a bit of pain, but a great learning experience / project for one on team not engaged in other duties.
Best is buy an existing commercial product such one listed below:
(purple-violet) designed for 12v motorcycle use!
for $14.99 on sale as of 1/20/14:
http://www.amazon.com/PURPLE-LED-Neo...productDetails
Product Description
4 PIECE LED NEON LIGHT KIT Complete Kit Comes With The Following: ●4 Separate LED Neon Lights With Wire Leads Use for all 12Volt Systems ●Two Styles of Mounting Hardware: Surface Mount for Anywhere, and Flush Mount for Plastic or Metal up to 1/8" Thick ●All Wire and Connectors for installation ● Switch with Leads ●Complete Installation Instructions ●Less than an hour to install THESE ARE RADLITES LED's THE HIGHEST QUALITY LED'S IN THE WORLD WITH THE LATEST TECHNOLOGY!! ●LED's will run over 100,000 Hours.. 11 years continuous! ●Very low Power Consumption 30ma each, 33 LED's per amp. You can leave them on all night and not drain your battery. ●Very small and easy to hide, and LED's do not generate heat. ●Brightest most efficient lighting, used everywhere!!
(I haven't used this product - I just googled it, but sounds perfect for your robot.. tho I'm a bit confused how 30mA per amp 33 LEDs statement relates, I think they are trying to say there are 4 strings of purple LEDs)
best feature: already ruggedized & for motorcycle use!, mounting, etc)
Connect it to a 20A resettable breaker and you are good to go (will turn on with 120A main breaker... you may wish to add a toggle switch as an additional local control.. or use a spike as suggested by others if you wish remote control (flash them via software, etc.)
I recommend aiming them down at floor or at structure within your robot so as to not challenge rules regarding interference with other robots vision system.
Good luck... Dale
