FRC 2530 Inconceivable Pneumatic Shooter
This is the final prototype. CAD is underway. Enjoy, and all questions are welcome.
https://www.youtube.com/watch?v=ui_Stx3uzlc |
Re: FRC 2530 Inconceivable Pneumatic Shooter
Hey team 2530:
I would love to see how that works closer up. Been fiddling with something similar too. thanks r3P0 team1504.. |
Have you done any testing to see how far it shoot or what the furthest distance from the goal is? Also accuracy, if you only have one small point of contact it might not be as accurate as you want. Just like playing pool, it works most of the time but the one time you miss is when you need it the most. Over all it looks good, you can make it into the goal and pneumatics unlike springs or surgical tubing will not loose effectiveness as it is used.
Blazeflipper - We were also concerned about accuracy of a puncher mechanism. That's why we have designed a secret method for assuring the ball is in exactly the same spot every time! We actually found a small strike plate (like the tennis ball shown) is more consistent than a larger strike plate.At an angle of inclination of 55 degrees, our range for the high goal is 3'7" - 5'3" in horizontal distance from the end of the field. As long as we are in that envelope, it doesn't miss. We were tempted to make a varying angle shooter, but then we have the problem of contacting the ball the same every time. KISS ![]() Last edited by one4robots : 21-01-2014 at 12:02. Reason: Additional response |
Funny just when you think you have come up with a unique solution.....
This design looks awfully familiar...
Any particular source you drew inspiration from? |
Team 178's video convinced us that it could be done.
Ah, cool.
It is very much like 95's 2008 shooter, too. It's a good, simple, launching mechanism. |
Quite possibly! Either way it's interesting to see multiple teams arrive at the same mechanism principle, arriving at it independently or by inspiration.
#11
Its really awesome to see that we are not the only team trying this kind of a shooting mechanism.
Thanks CJ! You too! |
#13
I assume this means you've done the same thing... Funny story: one of our mechanical students said, "I wonder if we could do a 2-stage shooter?" Our researchers immediately turned to CD and found Team 178 has something similar, too.I look forward to comparing our final designs in Milwaukee! See you there! Vince |
#14
Or the applicator mechanism that twirls it onto the tennis ball between shots. ![]() |
#15
