Go to Post I'm a drive team coach, they don't eat lunch during competition. - Rick [more]
Unread 21-01-2014, 16:36
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Pneu to pneumatics
I haven't been able to find this on screenstepslive. We have a spike wired to our compressor. The Compressor class in java also requires a digital input to tell when to turn off the compressor. What should we use to provide this signal?
Also, we would like to be able to set the pressure to two different settings; one for passing and one for shooting. If I use the high pressure, for the digital input to my compressor class, I figured I could use the low pressure digital input as a separate input that would shut off the compressor at the lower pressure setting.
How does one adjust the pressure set point on the KOP pressure switches? One of our students tried adjusting the set screw, but the set point didn't seem to change from about 100psi.
Unread 21-01-2014, 16:49
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
The digital pressure switch is what goes into the digital input to control the pressure. It has to be able to shut off at 120 psi.
You can't have 2 different pressures feeding the same cylinder.
I'm not sure which KOP pressure switches have set screws and are uncalibrated. The relief valve, which vents excess pressure, doesn't have a set screw, but may come uncalibrated. One of the hex rings loosens the switch, another does the actual adjustment, and the last is rigid for fitting the valve onto the compressor or fitting.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 21-01-2014, 16:50
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
Team Role: Coach
Rookie Year: 2007
steinra is on a distinguished road
Re: Pneu to pneumatics
Make sure to look at the pneumatics section in the rules as it will help with the wiring question you have. But to help answer it, there is a pressure switch that is in the high side of the circuit that will change states when 120 PSI is hit. This single is passed to a digital input that you specify on the constructor in java for the compressor class.
I will let others talk to the rest of your question on if it can be done legally or not per the rules.
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Not sure you really want to change the pressure by controlling the compressor. They are not the highest volume compressors and take a long time to charge a system. What you can do is have a high and low pressure leg on your pneumatics system. Just have 2 outputs from your storage tank feeding 2 pressure regulators set at different pressures. One goes to your high pressure solenoid and the other to your low pressure solenoid. Just remember to have a gauge attached to each regulator.
This is from the pneumatics manual and will help wiring the pressure switch.
We have included a pressure switch manufactured by Nason. This switch is normally
closed. The switches will open at approximately 115 psi and will not close again until the
pressure drops to approximately 95 psi. This will allow you to turn off the compressor once
you are up to 115psi, saving power in the battery. It must be wired directly to a digital
input and ground port on the Digital Sidecar. No specific GPIO port is designated for the
pressure switch. The cRIO must be programmed to react to the GPIO port that is connected to the
pressure switch. The cRIO will activate the designated Spike Relay to turn the compressor “on” and
“off”. There is no default program in the cRIO to control the compressor power. Do not put the pressure
switch in series with the power supply to the compressor.
Hope that helps.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 21-01-2014, 16:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
You should have a pressure switch (http://www.andymark.com/product-p/am-2006.htm) that connects to the DIO. Wire it between ground and signal.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 21-01-2014, 17:50
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
Rookie Year: 2011
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
You can switch between two pressures. It is actually quite simple. using a single solenoid manifold, You can achieve this using the exhaust ports as inputs and the pressure port as an exhaust.
