Go to Post Just wear your safety glasses. They can be stylish, too! - Eugenia Gabrielov [more]
Unread 21-01-2014, 17:01
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
Rookie Year: 2012
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Exclamation We Need Serious Robot Help!
Our robot doesn't drive at all! I'd give more details, but there are too many to list! Ask me any question you want that could help you understand what is wrong with our robot! We're in the workshop right now, so we can try anything now on our robot that could help it roll! Please help us!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 21-01-2014, 17:03
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: We Need Serious Robot Help!
Programming language?? post code
Post picture of wiring
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 21-01-2014, 17:14
Rookie Year: 2012
We program in Labview. I attached pictures from the three VIs, but I'm not able to give you pictures of the wiring.
ID:	15894  Click image for larger version
ID:	15895  Click image for larger version
Unread 21-01-2014, 17:19
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
In the first VI your "Open 2 Motor" VIs are set to rely on a single PWM. That might not be the only problem, but it could cause issues later on.
Unread 21-01-2014, 17:27
Rookie Year: 2012
It's because, physically, they are. Go to http://wpilib.screenstepslive.com/s/...control-system and do a ctrl+f to search for "4 Controllers - PWM Cables".
Unread 21-01-2014, 17:33
AKA: Ethan
Rookie Year: 2012
Sorry. I'm used to running a tank drive with four different PWM cables.
If you have anything that you can test power output with, try it on the motor controllers and post it here. That may help us to narrow down possible causes for your problem.
Unread 21-01-2014, 17:38
Rookie Year: 2012
On the red plus sign of the talon, there's 11 volts. On the other side, it's 0 volts.
Unread 21-01-2014, 17:40
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Does your joystick show up on the driver station?
If it does, is it in the right slot/configuration?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 22-01-2014, 08:21
Rookie Year: 2012
Yes and yes again.
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
You should probably list your setup, the things you've tried, and the exact problems you are currently running into (more specific than "It won't drive!!!").
Unread 21-01-2014, 17:04
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Pictures are good too.
Unread 21-01-2014, 17:10
AKA: Ethan
Rookie Year: 2012
What color are the lights on your motors?
Have you reimaged your cRIO this year?
Is everything correctly wired into the PD board?
Does the driver station indicate that you are connected to your robot?
Unread 21-01-2014, 17:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
What motor controllers are you using?
Is the PWM seated in all of them properly.
Does your drivetrain spin fairly easily without the motors?
Is your digital sidecar properly powered?
Are your motors trying to fight each other in the gearbox?
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 21-01-2014, 17:21
Rookie Year: 2012
The PWMs are properly seated. We can still turn the drivetrain by ourselves. How can we tell if the DSC is properly powered (only 2 out of 3 LEDs are on). No, our motors aren't fighting against each other. Does that help?
  #15   Spotlight this post!
Unread 21-01-2014, 17:23
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I told you how to in your 2nd thread.
Originally Posted by Joe Ross View Post
I suspect that both this problem, and your previous talon problem both have the same root cause, not properly powering the Digital Sidecar.
Remove the DB-37 cable from the digital sidecar and verify that all 3 power LEDs on the Digital Sidecar are brightly lit. If they aren't, make sure the digital sidecar is powered from a 20amp circuit from the PDB.
By creating 3 different threads, and not following the advice in previous threads, you're making it harder to help and take longer to get to the root cause.
