Go to Post Too often we like to forget that it takes an insane amount of hard work to even have a chance to overcome raw talent. - Paul Copioli [more]
Unread 21-01-2014, 17:29
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
Rookie Year: 2012
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Re: We Need Serious Robot Help!
Originally Posted by Joe Ross View Post
I told you how to in your 2nd thread.
By creating 3 different threads, and not following the advice in previous threads, you're making it harder to help and take longer to get to the root cause.
I followed your advice, but it still doesn't work.
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 21-01-2014, 18:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
What did you do? When you removed the DB-37 cable, which power LEDs (if any were still lit). List them by name. How did you verify power to a 20 amp breaker on the PDB? Find a mentor who is proficient with a multi-meter to verify 12 volts at the Digital Sidecar power connector.
Your programming is also wrong, as pointed out by other people. However, do not ignore the power LEDs on the Digital Sidecar, even if the software changes "fix" your immediate problem. You need to get the Digital sidecar power fixed or else you will have more problems down the road.
Unread 22-01-2014, 08:38
If you believe the electronics are in better shape, lets talk about how to debug SW.
If you go to RobotMain and press the run button, the code will download and start running. At that point you can open TeleOp and other subVIs and see values on their panels. You can open their diagrams and right-click to probe wire values.
So, after you are running your code, go to the Driver Station and Enable the robot for TeleOp mode. Open the TeleOp VI and determine if the joystick is making it to the robot and tracks physical joystick input values. If so, move to the Robot Drive code. It actually returns the values that it sent to the motors and by default those were being written to the SmartDashboard so that your could see what the SW was sending. Since that code has been deleted, you may want to wire it to indicators. Right click on the outputs and create indicators.
Determine if the SW is sending useful values to the motor controllers.
If you aren't making progress, you may want to open an example, set the PWM values and verify your electronics with that. You may also want to create a new robot project, set your PWM values in Begin, but don't delete and decorate the code so much until you know that it works.
Greg McKaskle
Unread 21-01-2014, 17:48
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Rookie Year: 2010
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
The PWMs are properly seated. We can still turn the drivetrain by ourselves. How can we tell if the DSC is properly powered (only 2 out of 3 LEDs are on). No, our motors aren't fighting against each other. Does that help?
If don't have all three LED's lighted on the digital sidecar none of your drive motors will work.
So go back to basics and check your wiring. The first place to start is with the digital sidecar and make sure are supplying 12 Volts NOT 5 volts to it. You get
12 volts from a 20 amp breaker on the PDB. Start with that and go forward one step at a time.
Unread 21-01-2014, 18:02
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
The colors on the Talons are the same (orange), but two flash and two are solid.
Which 2 are solid? Are they on the same side or different sides?
Flashing orange means the Talon isn't getting any signal. Solid orange means the Talon is getting a signal, but it won't output anything since that signal is 0.
If it's flashing, it could be a code issue or a wiring issue. If it's solid, it's most likely a code issue, since the code has to be the one to send the Talon a signal of 0.
On the red plus sign of the talon, there's 11 volts. On the other side, it's 0 volts.
I don't think this is the issue, but replace your battery with a fully charged one just to be sure.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 22-01-2014, 08:23
Rookie Year: 2012
My bad, all three are now and changing the battery doesn't work either.
Unread 22-01-2014, 08:34
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
We really need pictures to help you. Somebody on your team must have an iphone with camera who would be willing to take a picture for you.
Anyway, the flashing orange light on the talon means the talon has power, but no signal. If you're using the code posted earlier, which is correct, and you followed joe's advice to remove all cables but the power one and confirmed that all three leds are lit, then you need to check your pwm cable. Is it plugged in the right way? Try flipping the connector. Is it plugged in all the way?
The solid orange light means that your code is wrong (make sure you copy what was posted) or your driver station isn't recognizing your joystick. Under the diagnostic tabs, what color does the joystick 1 indicator turn when you push a button?
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Check your wiring.
All power should be wired according to this diagram.
All data (PWM, camera, and sensors) should be wired according to this diagram.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 21-01-2014, 18:09
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
Rookie Year: 2012
chris.boyle is on a distinguished road
I suspect that since you opened two instances of the drive system, they were competing with each other.
I'm enclosing a VI that shows how we opened our Joystick and the Archade Drive System using 4 motors. The code only identifies a 2 motor drive system, the "Y" cable from PWM1 goes to both motor controllers on the left side and the "Y" cable from PWM2 goes to both motor controllers on the right side. All motor control's MUST be of the same type; ie: Talon, Victor, Jaguar.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 21-01-2014, 18:37
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
Rookie Year: 2011
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
This is almost certainly the problem.
You only need to have one drive system, the default arcade drive code works fine for your application and did not need to be changed.
I've attached a photo if you don't want to download Chris's code.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 21-01-2014, 21:59
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
Team Role: Mechanical
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
The code is the a problem. You are commanding the same motor to go forward and reverse at once, making it not move.
This is actually not a direct result of using two drive systems (they cannot fight each other, drive one only uses PWM 1 and drive two PWM 2). The problem is because you have configured the left and right motors on each drive to feed to the same PWM, and then inverted one of them.
So your code works like this (when you go forward).
-->Get joystick value (1)
-->Set leftmotor to inverted joystick value (-1)
-->Set rightmotor to noninverted joystick value (1)
-->Left motor is PWM 1, set PWM 1 to value of -1
-->Right motor is PWM 1, set PWM 1 to value of 1
Nothing ever happens because you make the motors go full forward and full backward as fast as the code can execute.
Use Chris's code, but modify it for 4 talons (or use y-cables)
Last edited by John : 21-01-2014 at 22:07. Reason: I should not have presumed that this is the only problem.
Unread 22-01-2014, 08:22
Rookie Year: 2012
Thanks, all three are on now, but what do i do next?
Unread 21-01-2014, 17:17
Rookie Year: 2012
Originally Posted by E Dawg View Post
What color are the lights on your motors?
Have you reimaged your cRIO this year?
Is everything correctly wired into the PD board?
Does the driver station indicate that you are connected to your robot?
The colors on the Talons are the same (orange), but two flash and two are solid. No, we haven't reimaged our cRIO this year. Everything is corretly wired on the PD board. The driver station says that we are connected to the robot. Anymore questions?
Unread 21-01-2014, 17:21
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
when you press forward on the joystick(s) what does your robot do?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
  #15   Spotlight this post!
Unread 21-01-2014, 17:28
Rookie Year: 2012
Nothing. Absolutely nothing.
