MY Begin Vi wont wire to anything else
MY Begin vi block wont wire properly on my main block diagram. if anyone can help please reply, also if needed i can email a screenshot of my begin vi.
Re: MY Begin Vi wont wire to anything else
You description is a little unclear, but I believe that you have the same problem as this poster.
http://www.chiefdelphi.com/forums/sh...hreadid=125032 |
The original Begin output was the error I/O from the joystick call. I'm not sure what edits were made to Begin, but is seems like you somehow selected the output and deleted it. If you right click on the output of the joystick and Create >> Indicator, you will have a new value on the panel. Step two is to go to the panel and connect the lower right terminal to that error cluster.
If this is not making enough sense, you can always Create a new Robot project using the New... or Getting Started window. Open the project just to see how it originally was. Greg McKaskle |
