New Programming Core needs help with simple motor control
We have created the simple motor control program found on the NI website. We can successfully deploy the code to the CRIO via the run button in Labview. When changing the value of the output the motor does nothing. We have two Jaguar motor controllers and we have tried both but neither work. The Jaguar motor controllers have the yellow light blinking on them. This indicates as far as I can tell that they are not initialized. I have checked the PWM cables and changed them out and switched them around to make sure they are plugged in the right way. No change. I have changed the digital side car. No change. I have changed the NI 9403 Module. No Change. I have changed the cable between the NI 9403 and the digital side care. No change. We have a light plugged into the RSL of the digital side car, I don't know if it should light up when the code is deployed but it is not. The 5v led is on steady. The BAT led barely lights up, but it is blinking. An extremely small led beside the RSL pins barely lights up, but it is blinking. Thanks in advance for your help.
