Go to Post This thread is making me all vaklempt. :) This is FIRST at its best! Advice, offers for spare parts, and even lunch! You all ROCK! :D - Cynette [more]
Unread 22-01-2014, 10:49
tmtmtm tmtmtm is offline
FRC #4633
tmtmtm is an unknown quantity at this point
6 volt circuit
Are we allowed to have a 6 volt circuit on our robot?
Unread 22-01-2014, 11:01
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Rookie Year: 2011
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: 6 volt circuit
It depends on what you are trying to do with it. If it falls into the "custom circuit" category (i.e. lights, camera, on-board vision processing board); then yes, you can have a 6V circuit, as long as it is powered from the PDB or it is a COTS computing device/camera with a built-in battery. There is also a 6V supply available on the digital sidecar to drive servos. We're going to need a little more information to determine if your particular application is legal, though.
Unread 22-01-2014, 11:22
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: 6 volt circuit
I don't see anything that specifically says that you can't create you own 6V rail on the robot! However, be careful!
Unread 22-01-2014, 12:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: 6 volt circuit
Tm,
Custom circuits can contain their own power supply within limits for custom circuits. If you have a COTS device that you are using i.e. a single board computer that requires that supply voltage, and it does not control any motors, solenoids or relays on the robot, then you are good to go.
Al
WB9UVJ
www.wildstang.org
________________________
