Go to Post Incidentally, this is a good example of why lawyering the FIRST rules is good practice for the real world. By critically analyzing FIRST's errors, you practice for the day when you need to critically analyze legislators' errors (and deliberate trickery). - Tristan Lall [more]
Unread 22-01-2014, 18:28
DarthMaulCIS DarthMaulCIS is offline
FRC #4607
DarthMaulCIS is an unknown quantity at this point
Deploying Issues
"No CompactRIO devices were found.
Verify an Ethernet connection between the CompactRIO device and this computer, and then turn Windows Firewall off while imaging the CompactRIO device."
I don't know what I'm doing wrong. I followed this tutorial almost to the letter.
http://wpilib.screenstepslive.com/s/...ging-your-crio
Unread 22-01-2014, 18:45
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Rookie Year: 2010
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: Deploying Issues
Do you have other connections on your computer? When I was imaging the cRIO with my laptop I had to disable my wireless and other wired connections, such as virtualbox, for me to deploy correctly.
Unread 22-01-2014, 20:51
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Rookie Year: 2011
Dexterium is an unknown quantity at this point
Are you using a crossover cable or a regular Ethernet? In order to image the RIO you need to use a crossover cable (usually yellow).
Unread 22-01-2014, 21:27
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Did you do the part where screenstepslive mentioned using a network switch between the PC and the cRIO? The DLink works fine for this.
Did you try a different computer?
As Kevin mentioned, Disable all other network connections beside the one Ethernet port you are using.
Check the Ethernet port address under Advanced to make sure extra IP addresses are not listed. Delete anything that isn't 10.te.am.5
